Better way to cut wood
   / Better way to cut wood #1
Boondox
Elite Member
Craftsbury Common, Vermont
Deere 4044R cab, Kubota KX-121-3S
In the old days I'd drag a log into a clearing, mark it, wire brush the dirt off the bark, cut halfway thru, use my Peavey to roll it over, complete the cuts, and roll the stove-length chunks over to the splitter.
With Clementine's help, I now lift the log off the ground with the FEL, move it right next to the splitter, mark and cut. The pieces fall to the ground right next to where they'll be split. Best of all, there's no imbedded dirt to dull my chains!
Check out the pic.
Pete
www.GatewayToVermont.com
   / Better way to cut wood #2
Pete,
I see you got your bucket hooks welded on, Must be working out for you. Did you do it yourself?
   / Better way to cut wood #3
I've found using the bucket to lift logs for cutting to be real useful too. Just be careful to cut from alternating sides so it doesn't become imbalanced and tip over!
I discovered another trick in place of marking the tree to get properly cut lengths of fire wood. Measure the desired length from the tip of your chain bar and mark the bar. Then just hold the bar along side the log to locate the correct cut location, and have at it. You can walk right down the log and dice it up in no time.
Peter
Actually they're not welded yet. Not till Monday. For now I just use hooks on both ends of a six foot chain...and lift very carefully! I called the local police and asked if it was legal for me to drive Clementine to the welding shop. "Technically it's not legal," was the reply. So I asked if they had any objections if I drove to the shop on a weekday when the tourist traffic was down. "Technically it's not legal," was the reply. So finally I asked if they would pull me over if they saw Clementine sashaying down Main Street. "We wouldn't mess with you," was the reply. "But technically it's not legal." /w3tcompact/icons/wink.gif
Peter -- The proper length for my stove is from the bartip to the end of the "Husqvarna" logo...but marking them gives my wife something useful to do. Can't figure her out. She'll gripe all day and half the night if I ask for help, but insist I must be upset with her if I don't ask. Being married gets pretty confusing at times.
Pete
   / Better way to cut wood #5
Pete
Did they give you a reason why it's not leagal? I asked my local law official and he said as long as you had the SMV sign and "lights" working it was to be o.k. Now that I mentioned it he told me it wasn't leagal or illeagal. I'll have to ask him again.
That would like to see you and Clementine at the three way stop in the middle of Stowe sipping on some of that GMR coffee, "sashaying"/w3tcompact/icons/laugh.gif!
Derek
   / Better way to cut wood #6
Pete,
What model Husqvarna do you have to compliment Clementine?. I run the 55 rancher along with Jezebel. I have driven Jezebel down the road and haven't had a problem with the local authorities. I don't think you will have a problem as long as you don't ram the police station!
Jason
   / Better way to cut wood #9
<font color=blue>...I'm not worthy...</font color=blue>
Then I can only guess your last name doesn't start with Fox...? /w3tcompact/icons/wink.gif
   / Better way to cut wood #10
John.....took me a minute....that is one BAD pun!!![grin][grin]
Kevin
2006 Ocmis 125 R4/2 (A50123)
2006 Ocmis 125...
2003 Club Car DS Electric Cart (A51694)
2003 Club Car DS...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2001 International 4700 Dump Truck (A51691)
2001 International...
2013 Dodge Charger Sedan (A51694)
2013 Dodge Charger...
Gravely Proturn 472 (A50123)
Gravely Proturn...
