Better snowplowing - plastic scraper blades 4FEL
   / Better snowplowing - plastic scraper blades 4FEL #1
frasierdog
Just cleaned the paved driveway for the first time yesterday using JD4110 FEL bucket. The float position still had too much downward force on bucket. My driveway is on curve and uphill, so one side of bucket digs first. Ended up using normal stick position and bucket angle to scrape, went pretty well.
Has anyone got better idea or seen a plastic bucket edge scraper that would save my asphalt?
I do need to use my bucket to place snow due to hill on both sides of drive, so plow blade alone won't help. I was thinking of modifying small snowblade to attach to FEL bucket that can be winched up to open bucket for snow placement.
Any ideas would help, I have learned a great deal from all of you thru this forum :>)
   / Better snowplowing - plastic scraper blades 4FEL #2
Search past posts for "horsemat", "stall mat", "conveyor belt", and/or "retread", etc. You will find alot of posts about this subject.
Mark
   / Better snowplowing - plastic scraper blades 4FEL #3
You can use a piece of black poly pipe. split the pipe slide it over the cutting edge and bolt it in place.
   / Better snowplowing - plastic scraper blades 4FEL #4
What I did was to bolt a 2 x 4 on either side of the bucket, 1 ½" width side down, about ½" below the front blade. Now it slides along the 1 ½" wide piece of wood and does not scratch the driveway. Worked great when picking up mulch dumped in the driveway this summer. I think it will do just a well with the snow and a lot $$ then $40 an inch. Two 18" 2 x 4, 4 -2 ½ by 5/16 bolts a few washers and nuts and about 30 minutes is all it takes.
Here are some pictures
web page
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
2008 Caterpillar 45kW C4.4 3-Phase T/A Towable Diesel Generator (A51691)
2008 Caterpillar...
UNUSED FUTURE FT-XJ7T 7 TON 46" HYD THUMB CLAMP (A51248)
UNUSED FUTURE...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
