Better seat
   / Better seat #1
meanmerc
Bronze Member
Qc, Canada
MF 1528 4x4
Has anyone installed a better seat for their tractor? Princess auto seem to sell a more comfortable and adjustable seat for a good price then what comes standard on CUT's. I have a 1528 massey, the seat is good but I'm sure I could fit something better????
   / Better seat #2
I put a suspension seat from TSC on my Mitsubishi, that was the best mod I have done to that tractor.
   / Better seat #3
I have a Kubota B6000 in the yard that the owner did some work to the seat, but didn't make it any more comfortable. He raised and extended the seat bracket an inch in height and a couple inches rearward. Made all the difference in the world as far as leg room. Being a steel seat, it didn't help much on rearend comfort, but as least the legroom is better!
David frm jax
   / Better seat #4
I put a new, better seat on my Kama.
It's a suspension type with armrests and I got it at Agri-Supply. It's pretty comfortable and is a lot better than my original one. While I was making it fit, I also made it so it could rotate from side to side or lock into the front position.
Here's the thread to it.
New Seat Finally
   / Better seat #5
Well that plastic material gave out on mine and it just so happened that I had some leather kicking around.
I remouved the old hardened (cold on the a--) plastic stuff and recovered with the leather.
WOW what a differance in comfort. It breathes!--so not hot and sticky in summer and surprise, very warm in winter.
Plus as luck had it the leather was Mitsubishi blue-perfect match!
   / Better seat #6
Leather sounds good,is there any secrects to get it to stay tucked in the corners,my mits 160 could use a new cover.My problem with the stock seat is the springs,my 240 lbs lets them sit on the rubber stoppers,is there a easy soures for a little stiffer spring.I tried to remove the old ones for a matchup,but what looks like a bolt head under the mount is welded,so its more then just a simple remove.Any aposterers (?) ou there?
   / Better seat #7
I added a couple of springs to the sides of the rubber bumpers under the seat of my Ford 1100 years ago, to ease the bumps going up my spine. One end of the spring sat on the tractor with a bolt running thru the center of the spring from the top, with a lock nut on the under side which floated when you compressed the spring with your weight.
David from jax
   / Better seat #8
I bought a cushion designed for wheel chair use on ebay for around $15 that is just awesome. I went from being fatigued and sore after a few hours of mowing, to being able to mow all day long and remain comfortable. It's a night and day difference.
Eddie
   / Better seat #10
John Deere 3025E (A50120)
John Deere 3025E...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52748)
2021 John Deere...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Mulcher (A52748)
2022 JCB 3TS-8T...
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
