Better seat belt
   / Better seat belt #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
My tractor seat belt almost cuts my gut in half when going downhill. Tightens up too much to turn around enough for backing the bush hog up over stuff. Have to remove it to get enough around to see behind.
Anyone have a solution to these problems? Maybe a bigger, more cushioned something that would slip over the extended seat belt?
Ralph
   / Better seat belt #2
Check with your local ATV shop. My side by side has a shoulder pad, maybe you could put the shoulder pad on the lap part of the belt.
   / Better seat belt #3
You could get a non ratcheting seat belt whose manual adjust won't self tighten. There's lots of belts available on line from places like seatbeltsplus
   / Better seat belt
Hmm. I've a pad on the shoulder belt part of the Tacoma's seat belt. Might try that.
Ralph
   / Better seat belt #5
   / Better seat belt #6
I also ordered a manual tightening belt from Seat Belts Plus to replace the gut killer seat belt on my Kubota. Easy to swap out, quick release buckle and easily adjustable.
2025 K2030 UNUSED Metal Garage (A50860)
2025 K2030 UNUSED...
2025 K1119 UNUSED Metal Carport (A50860)
2025 K1119 UNUSED...
(3) VACUUM PUMP TANKS (A50854)
(3) VACUUM PUMP...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
Gang Box (A50860)
Gang Box (A50860)
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
