Better RIde R-1's or R-4'S
   / Better RIde R-1's or R-4'S #1
JLoaf
White Co., ARKANSAS
Kubota L3830 DT & B2710
Better RIde R-1\'s or R-4\'S
I'm about to buy a new L3830. I want the best riding tire as far as comfort to my back, etc /forums/images/graemlins/blush.gif is concerned. I think that R-1's or R-4's will do what I need them to do. Any opinions?
   / Better RIde R-1's or R-4'S #2
Re: Better RIde R-1\'s or R-4\'S
If the only criteria were ride confort, then your choice would be turf. Since that's not the only one I personally would say R-1's have more bounce than the 6 ply R-4's that I have. Taking into account air pressure I would say that pressurized the same there is probably not a lot of difference between them but there is a difference in the R4's I have now and the R1's on the Fergie.
   / Better RIde R-1's or R-4'S #3
My gut feeling is that the R1's would deliver a slightly smoother ride. I run my R4's at well below the recommend PSI. When the front bucket is really loaded, I have enough pressure in them to only be slightly flat. I think that by lowering the pressure, I get a little better ride and more importantly, more traction then when fully inflated. For what may be well the best riding tire available, a fellow here has a set of Michelin radial tires on his new L3130. We are anxious to hear his results. Rat...
   / Better RIde R-1's or R-4'S #4
I can go beyond and tell you that the farm tires will give you the best ride. The industrials will carry the most load.
   / Better RIde R-1's or R-4'S #5
My personal preference for all round use is R1 (might be different if my primary job was lawn mowing), so R1 is the only thing I've owned, although I've used a tractor with R4s. I've never used a tractor (only riding mowers) with turf tires, and I would have thought the turf tires would give the smoothest, softest ride, but I also know that Art knows more about it than I do, so I'll bet he's right. /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
   / Better RIde R-1's or R-4'S #6
Rat, if he doesn't load them that will be the smoothest ride! Love them radial tires!
   / Better RIde R-1's or R-4'S #7
My tractors are comparable to each other in weight, but smaller than yours. I have a Ford 1210 and a Kubota B7500. Tha Ford has R1's and the Kubota has R4's. The R1's ride smoother, absorbing the bumps better. It's not a day and night difference as long as I don't air the R4's up. With more than 12 or 15# in the R4's they are pretty stiff. I went as low as 7# with the R4's and spun one rear on the rim while under a heavy load. I loaded the R4's, but that didn't make much of a difference in ride before vs. after.
The Kubota has a loader, and I prefer to stay with the R4's on it because of that. Both designs work fine for me. Neither tears up the grass unless I run in 4WD or turn real sharply when the ground is wet....................chim
   / Better RIde R-1's or R-4'S #8
Bird the turfs should be the smoothest ride no doubt! The question just didn't include them.
   / Better RIde R-1's or R-4'S #9
Are you sayin' I oughta read the question, Art? /forums/images/graemlins/crazy.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif Thanks. /forums/images/graemlins/laugh.gif
   / Better RIde R-1's or R-4'S #10
Here's a q then, are the R-4 fronts smoother on the road? I was working on the weekend and running half worn R-1's on the road had the axle set into oscillating vibrations and shakes the loader like crazy!
Ken
2015 FORD F550 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XL...
2024 CATERPILLAR 289D3 SKID STEER (A52705)
2024 CATERPILLAR...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2010 Club Car Precedent Electric Golf Cart (A55758)
2010 Club Car...
2001 TOYOTA TACOMA SRS TRUCK (A54756)
2001 TOYOTA TACOMA...
