Better RIde R-1's or R-4'S
   / Better RIde R-1's or R-4'S #1
JLoaf
White Co., ARKANSAS
Kubota L3830 DT & B2710
Better RIde R-1\'s or R-4\'S
I'm about to buy a new L3830. I want the best riding tire as far as comfort to my back, etc /forums/images/graemlins/blush.gif is concerned. I think that R-1's or R-4's will do what I need them to do. Any opinions?
   / Better RIde R-1's or R-4'S #2
Re: Better RIde R-1\'s or R-4\'S
If the only criteria were ride confort, then your choice would be turf. Since that's not the only one I personally would say R-1's have more bounce than the 6 ply R-4's that I have. Taking into account air pressure I would say that pressurized the same there is probably not a lot of difference between them but there is a difference in the R4's I have now and the R1's on the Fergie.
   / Better RIde R-1's or R-4'S #3
My gut feeling is that the R1's would deliver a slightly smoother ride. I run my R4's at well below the recommend PSI. When the front bucket is really loaded, I have enough pressure in them to only be slightly flat. I think that by lowering the pressure, I get a little better ride and more importantly, more traction then when fully inflated. For what may be well the best riding tire available, a fellow here has a set of Michelin radial tires on his new L3130. We are anxious to hear his results. Rat...
   / Better RIde R-1's or R-4'S #4
I can go beyond and tell you that the farm tires will give you the best ride. The industrials will carry the most load.
   / Better RIde R-1's or R-4'S #5
My personal preference for all round use is R1 (might be different if my primary job was lawn mowing), so R1 is the only thing I've owned, although I've used a tractor with R4s. I've never used a tractor (only riding mowers) with turf tires, and I would have thought the turf tires would give the smoothest, softest ride, but I also know that Art knows more about it than I do, so I'll bet he's right. /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
   / Better RIde R-1's or R-4'S #6
Rat, if he doesn't load them that will be the smoothest ride! Love them radial tires!
   / Better RIde R-1's or R-4'S #7
My tractors are comparable to each other in weight, but smaller than yours. I have a Ford 1210 and a Kubota B7500. Tha Ford has R1's and the Kubota has R4's. The R1's ride smoother, absorbing the bumps better. It's not a day and night difference as long as I don't air the R4's up. With more than 12 or 15# in the R4's they are pretty stiff. I went as low as 7# with the R4's and spun one rear on the rim while under a heavy load. I loaded the R4's, but that didn't make much of a difference in ride before vs. after.
The Kubota has a loader, and I prefer to stay with the R4's on it because of that. Both designs work fine for me. Neither tears up the grass unless I run in 4WD or turn real sharply when the ground is wet....................chim
   / Better RIde R-1's or R-4'S #8
Bird the turfs should be the smoothest ride no doubt! The question just didn't include them.
   / Better RIde R-1's or R-4'S #9
Are you sayin' I oughta read the question, Art? /forums/images/graemlins/crazy.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif Thanks. /forums/images/graemlins/laugh.gif
   / Better RIde R-1's or R-4'S #10
Here's a q then, are the R-4 fronts smoother on the road? I was working on the weekend and running half worn R-1's on the road had the axle set into oscillating vibrations and shakes the loader like crazy!
Ken
1979 MACK R MODEL (A53843)
1979 MACK R MODEL...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
Golf Cart (A55787)
Golf Cart (A55787)
2015 Nissan Altima Sedan (A55853)
2015 Nissan Altima...
