Better Oil Filter for my eMax22
   / Better Oil Filter for my eMax22 #1
shovelmike
Platinum Member
Rural Missouri
Ferguson TO35 , Mahindra eMax 22, Hustler Super Z
When I performed the 50 hour oil and filter change on my tractor last Spring the first realization was that the factory put the filter on really tight. My second realization was that there is no working room around the filter. There was no way to use the usual filter wrench with a handle for leverage, and the end cap style only spun.
I ordered a three jaw filter wrench removed the old filter, and installed the new.
I was using the tractor a couple of days ago, and noticed a steady drip from the filter, removed and inspected for damaged gasket. No damage, but it is a small o-ring instead of the flat gasket I am accustomed to in automotive applications. I tightened it as tight as I dared, and still saw a slight drip.
Seeking to improve the situation, and noting the 1 inch hex on the end of K & N filters, I looked up a cross reference. Mahindra E520532091 = K & N HP 1004. The K & N also has a flat gasket! Swapped to the K & N and now have no leak.
K & N was $15 on Amazon, same price at O'Reilly...ordered 10:30 this morning and picked it up at 1:30 this afternoon.
K & N is my go to filter now.
2005 FREIGHTLINER COLUMBIA SLEEPER (A54313)
2005 FREIGHTLINER...
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
2022 CATERPILLAR 303.5 CR EXCAVATOR (A52705)
2022 CATERPILLAR...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2016 IZUZU NPRXD S/A BOX TRUCK (A52706)
2016 IZUZU NPRXD...
2005 Ford F-650 2,000 Gallon Water Truck (A53422)
2005 Ford F-650...
