Best Welding accessory I ever bought
   / Best Welding accessory I ever bought #11
I tried the Tig pen, I found it was easier to just feed by hand. Now for some reason I find it even easier to hold the torch with my off hand, and feed with the other hand, go figure! :confused2:
   / Best Welding accessory I ever bought #12
RoMad said:
My youngest son is home from school for the summer and had said he would like to learn to weld. I posted a thread asking about welding hood advice and ended up buying one with an auto lense from Amazon.com.
On Sunday we went over how the hood worked and I showed him how to run a flat bead and a lap joint using 6011 in my buzz box. I left him out in the driveway welding together a bunch of my scrap metal for about 3 hours. Sunday evening he said he was ready to help me build a counterweight for my tractor that I had been talking about. He showed me his welds and he really was picking it up pretty fast.
On his second day of welding we made the counterweight out of a bunch of metal they gave me at work and a drawbar I had bought from ebay. I made sure that all of his welds were flat lap joints and held his hands a couple of times to help him get the hang of it. Once again he did a pretty good job. At one point after about an hour of welding he said "this sure is hot work" which tickled me since i spent many hours in the hot sun, in boilers, tanks, and vessels welding when I was his age.
All in all a lot of fun watching him learn and pretty darn nice to sit in a lawn chair while he does the hot work. I should have bought another hood a long time ago :laughing:
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=269281"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=269280"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=269279"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=269278"/>
Glad to see that you are teaching your son a valuable skill that will serve him well in life!
Don't mean to be the safety police but...
In the picture of him welding his mask/head is directly in the plum. I know I have done this numerous times in the past and have paid with black soot coming out of nose and throat for days.
I now wear a N95 mask (fancy dust mask) that catches most harmful particles when stick welding/grinding or plasma cutting.
Just food for thought
   / Best Welding accessory I ever bought #13
Good point!
I think it was in the 1970s when the memos from the safety department changed their tune from concerns about our eyes to our lungs. Then in the early 1980s I worked in a tank shop building stainless steel and high carbon steel tanks. The big concern was being inside the tanks and drowning on the argon gas when Tig welding. Can you believe they would make us sign a statement at each Monday morning tool box safety meeting, that every night we sat with our azzes above our heads for at least 30-minutes so the argon could drain out of our lungs!
   / Best Welding accessory I ever bought #14
Shield Arc said:
Good point!
Unbelievable!
But I do believe you
   / Best Welding accessory I ever bought #15
snip
WOW! Really? Is this still a viable / plausible scenario? That is down right scary!
I wonder if there is a ARGON sniffer and after running gas all day you come home,
jump on the easy hangups machine / body inverter and see if you get readings
of Argon out of your lungs!
I guess it is plausible...:lifepreserver:
   / Best Welding accessory I ever bought #16
Not good!
Probably why SAR (Supplied Air Respirators) are now required
Health effects of argon
Routes of exposure: The substance can be absorbed into the body by inhalation.
Inhalation risk: On loss of containment this liquid evaporates very quickly causing supersaturation of the air with serious risk of suffocation when in confined areas.
Effects of exposure: Inhalation: Dizziness. Dullness. Headache. Suffocation. Skin: On contact with liquid: frostbite. Eyes: On contact with liquid: frostbite.
Inhalation: This gas is inert and is classified as a simple asphyxiant. Inhalation in excessive concentrations can result in dizziness, nausea, vomiting, loss of consciousness, and death. Death may result from errors in judgment, confusion, or loss of consciousness which prevent self-rescue. At low oxygen concentrations, unconsciousness and death may occur in seconds without warning.
The effect of simple asphyxiant gases is proportional to the extent to which they diminish the amount (partial pressure) of oxygen in the air that is breathed. The oxygen may be diminished to 75% of it's normal percentage in air before appreciable symptoms develop. This in turn requires the presence of a simple asphyxiant in a concentration of 33% in the mixture of air and gas. When the simple asphyxiant reaches a concentration of 50%, marked symptoms can be produced. A concentration of 75% is fatal in a matter of minutes.
Symptoms: The first symptoms produced by a simple asphyxiant are rapid respirations and air hunger. Mental alertness is diminished and muscular coordination is impaired. Later judgment becomes faulty and all sensations are depressed. Emotional instability often results and fatigue occurs rapidly. As the asphyxia progresses, there may be nausea and vomiting, prostration and loss of consciousness, and finally convulsions, deep coma and death.
Read more: http://www.lenntech.com/periodic/elements/ar.htm#ixzz1yUQnfw7g
   / Best Welding accessory I ever bought #17
I purchased the Hobby Air system for my shop due to the fact that i didn't like seeing all the smoke given off by my plasma cutter. Now i use this system whenever i weld or use spray paint . It used a pump and a hose to bring in outside fresh air into a respirator mask to keep me breathing clean air.
I also improved my welding skills 100% overnight when i broke down and purchased my Jackson Boss auto darkening hood.
Why i waited so long is beyond me.
   / Best Welding accessory I ever bought #18
Setting in the shade watching the son work. What a deal! I've about forgot that feeling. My two are out of the house on their own.
Great job
RC
   / Best Welding accessory I ever bought #20
My dad taught me how to weld back when I was real young helping out on the farm...
I have repaired lots of equipment over the years with a simple buzz box...
Great job...
I am sure that your son will look back on this experience and cherish it just as I do now...
UNUSED RAYTREE RMDM72 - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
New JMR Mini Skidloader 40" Grapple (A50775)
New JMR Mini...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
2015 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2015 Ford F-350...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2019 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A52705)
2019 CATERPILLAR...
