Best ways to move rocks/boulders
   / Best ways to move rocks/boulders #11
Gorgeous photo! You have a beautiful place.
I don't have much to add. My only suggestion is I've seen a poster recommend a small automobile hood as a sled for rocks.
I did this when I lived in MA ...used a chain and my truck with an old plymouth hood ... worked real well !
All great ideas!
California - thank you for the compliment especially from you with that beautiful orchard!!!!
I can't afford to add a grapple - I actually probably could afford it but not the divorce attorney it would result in!
I think I have to get better at getting the bucket under the rocks. The curl is not strong enough to lift them up but I know the loader can lift them...so it might that I need a lot of practice to get the rock to roll back in to the loader.
Since I will need to do more than one course of rocks I think I may get real good at using the loader and probably removing a few from the pond!
   / Best ways to move rocks/boulders #13
How about adding a set of pallet forks to the bucket and sliding them under the rock?
   / Best ways to move rocks/boulders #14
Just as YannyMan said, I remove the QA bucket and connect the forks. Then, I adjust the width of the forks so I can drive up to the rock and slide the forks under each side. The loader's greatest power (breakout force) is when it's lowest. So, though you can't curl the bucket with the rock inside, you should be able to lift it off the ground a few inches with forks unless the rock is just too big for your machine.
   / Best ways to move rocks/boulders #15
How big is the bucket? If they won't fit a 'normal' sized bucket, they must be pretty big (heavy) boulders.
You mean like this? This rock weighs about 2000 lbs. and is in a 5' bucket. Rocks weigh anywhere from 150-175 lbs. per cubic foot depending on the type.
   / Best ways to move rocks/boulders #16
The way to move big rocks is with a stone boat. About 24" wide 6' long with a turned up front lip (usually steel) has a chain on the front. roll the rocks on pull them to where you want them and roll them off. Mine is made of Black Locust strong as heck and resist rot.
Joe
Joe
   / Best ways to move rocks/boulders #17
never heard of a stone boat until now. Googled & found this. Is this a stone boat ?
   / Best ways to move rocks/boulders #18
Just say goodbye to your lawn...
I think I will try a few of these ideas. Its funny about the stone boat. I have some very thick marine plywood that I have used before to move rocks with my SS12 Suburban. I just lift one edge up and pull. for the larger ones I was thinking of mounting a pair of old ski's to just give it enough upward pull.
However, I think the best approach is to use some counter weight, get the rock into the bucket or lift it via chain and then place it where it needs to go.
   / Best ways to move rocks/boulders #20
I sold my Sears SS16 Twin Onan last year. ;)
I still have a front mount chipper/shredder that's been used once in its life for one of those tractors.
FORD 2000 TRACTOR (A51243)
FORD 2000 TRACTOR...
UNUSED AGT MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED AGT MINI...
2007 Chrysler 300 Sedan (A50324)
2007 Chrysler 300...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2017 Case 1150M Dozer (A50514)
2017 Case 1150M...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
