Best way to yank out shrubs? Etc..
   / Best way to yank out shrubs? Etc.. #51
   / Best way to yank out shrubs? Etc.. #52
Can you recommend a drawbar for the BX2370-1?
It should have come with a fixed drawbar or see your dealer. If you want the movable bar between the lower links than you could use one of these.
CountyLine Cross Drawbar, Category with Category 1 Pins - For Life Out Here
This is a Cat 0 bar with Cat 1 pins and is 20 inches long. Look at and measure your lower links width, but I think the above one will fit, and I am pretty sure your pins size is CAT 1 (7/8 inch) even though you actual size of the hitch is more like CAT 0. I believe they call this limited CAT 1
By the way you will need a drawbar lock also if you want to put a ball on the movable drawbar between the 3pt lower links.
CountyLine Drawbar Lock, Cat 1 - For Life Out Here
   / Best way to yank out shrubs? Etc.. #54
My draw bar is pretty whimpy, compared to my tacoma truck hitch. I think JD rates it for only 5-600 pounds (pull force).
   / Best way to yank out shrubs? Etc.. #55
:D If you need a little more leverage:
   / Best way to yank out shrubs? Etc.. #56
And BTW, I lifted my back tire about a foot yesterday, yanking/lifting a root from the front end. It happened very fast ... be careful out there - no one needs a roll over.
   / Best way to yank out shrubs? Etc.. #57
Wouldn't the 3pt pull brush up like that?
   / Best way to yank out shrubs? Etc.. #58
Dangerous, that will raise the front off the ground instead. Then you may slew sideways, with nothing to keep the tractor pointed in the same direction. I once tried this plus a little forward motion in crawl gear. Never again!!! The nose came up two feet instantly, could have walked the tractor right over backward if I hadn't gotten the clutch in fast enough. Don't Do This.
One extremely dangerous method to avoid is chain a tire to the bush then drive forward. Many fatalities that way. Similar but not recommended, chain the front of the tire to the bush then drive backward. This can break stuff.
You need steady controlled motion to pull anything safely.
   / Best way to yank out shrubs? Etc.. #59
I have done/seen many stupid things with a tractor and other pieces of machinery that could have caused a fatal accident. Several of those stupid actions were pulling things, stumps, trailers, etc., without stopping and considering the forces involved. Once you get everything set up step back and look at what you are attempting to do for about a half minute or so. You may have one of those "Oh siht" moments when you realize you would have hurt yourself if you had continued.
Last summer I had my wife back over a small rise in our yard with a very large limb chained high under the loader. She was at an angle to the slope. Saw left back tire come a couple feet off the ground before she could get it stopped. I rode the fender while she s-l-o-w-l-y drove forward. Then had her lower the bucket some and back down the same slope straight and turn at the bottom with no problem.
Be aware of forces and angles, levers and fulcrums. Tractors are incredibly useful tools but if misused incredibly dangerous.
If you don't know what I'm talking about then use a tractor for a while and you will.
Just saying.
RSKY
   / Best way to yank out shrubs? Etc.. #60
*EDIT* DOH! helps to pay attention to page numbers of a thread.. did not see extra pages...
never use long chain between tractor and what you are pulling without taking precautions. long chain = deadly whip when things go bad, and comes flying back taking your arm / head / torso off the rest of you.
long chain, also = ropes, straps, cable, etc... shorten them up. there are ways to reduce whip effect. but try to avoid it if all possible. short length between end of tractor and what you are pulling.
-- been there done that. and amazed i am still alive and un-injured. in stupid moments i have had.
never hook up. and just gas peddle through floor board for high RPMs. and then going into gear for a sudden jump start to the end. you damage tractor, and you flip tractor over killing you.
that last one is a pain to deal with. given a little more gas, and then a little more, then a little more, then tractor wheels start a bouncing, like on a bunking bronco roodoo show.
keep it slow, keep it in lowest gear. keep your foot and hands on brakes, clutches, etc... so stop the tractor and let it come back down on all wheels.
make sure your roll cage is in working order and up.
if you are thinking of pulling stuff at angles and what not to tractor. make sure you get the extra sway bars / chains, check chains, and like for 3pt hitch. good chance you got slime down 3pt hitch setup. without all the extra bars / chains. that help strength the 3pt hitch. for side to side play.
bushes, i tend to wrap the bloody main trunk on it, a 2 to 4 times around. and do my best so when chain tightens. the chain itself tightens around the main branch itself. hopefully the extra limbs / branches help hold the chain on the main branch some what. for stubborn fence posts you might need to attack fence post / shrub at a couple different angles (hooking up / un hooking each time) and moving tractor to a different angle.
3pt hitch most likely going to have more "lift capacity" than FEL, but issue is getting tractor backed up. and hooked up low and as near as possible (within reason) to 3pt hitch.
A frames and old steel wheel rims. can be a benefit for stubborn shrubs. the A frames and old wheel rooms. allow you to change direction of pull. instead of side ways. they help you create a "pulling force upwards".
tree spades (i tend to see more bolt on spades for FEL general duty buckets), can be a easier way to dig up around trees / bushes. to loose up dirt and more so bust up the roots.
a backhoe, for example TLB (tractor loader backhoe), can be nice to dig in and around trees / shrubs. and tear up and take out roots going to main trunk.
mini ex (mini excavator) / excavators, just the backhoe a seat and engine nothing else. tend to be more maneuverable and allow a bit more freedom getting in and around in tight areas.
a thumb for backhoe / excavator. can be rather nice, being able to simply move backhoe out and grab stuff. pending on thumb. some have more of a "knife" like blade to them. or bucket itself for more of knife / jagged edges.
some folks have used a potato plow, and other single metal knifes per say that go into ground. and run them around trees / shrubs. to cut up roots.
trees, if you cut them down and leave say 5 to 6 feet of trunk left (not cutting it off at ground level) but cutting the top off up higher from ground. you can use the higher end of trunk like a lever, and push / pull.
be careful if you use the FEL (front end loader), and try and get one corner of the bucket under a root and try and pry the root / tree / shrub out. you could possibly twist the FEL arms. granted FEL's tend to be fairly strong. but you can set yourself up in the extremes and twist the FEL arms resulting in a bucket that is no longer level. and costly repairs to re-level.
some folks have used 'stump burners" cutting the top off, and then putting an encloser over stumps with some holes in correct places. and setting a blaze.
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
John Deere Tractor Weights (A57149)
John Deere Tractor...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
2007 Honda Odyssey Van (A56859)
2007 Honda Odyssey...
2023 Chevrolet Tahoe FL SUV (A56859)
2023 Chevrolet...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
