Best way to vertically lift phone poles for fence
   / Best way to vertically lift phone poles for fence #1
hal2001
Kubota b7800
I have a Kubota 7800 30 HP and a set of forks and a logging chain. I want to lift 16 inch diameter nine foot long poles into the ground to anchor my grape vines. Very heavy. The weight is not a problem I can lift them horizontally but I'm hoping to hover them over the 3 foot hole and place them from a vertical position. Many years ago I helped a neighbor do this and he had figured out a way to do this using one chain wrapped in such a way that it would not slip or move about much. He's gone and other than trial and error (dangerous) I'm hoping someone knows the best way to accomplish this. I can place lag bolts or anything else I need to do this safely.
_"I may not do good work....but I sure am slow"
   / Best way to vertically lift phone poles for fence #2
To attach a chain with minimum slippage you wrap the chain around and instead of hooking to it,wrap the tag end around the main chain and hook it to itself forming a loop. This creates a choker that gets tighter as you lift. Then you figure out placement to get it as vertical as you can.
   / Best way to vertically lift phone poles for fence #3
Then run the long end over the top of the post and hook it to the other side of the loop. Lift from this section of the chain at the end of the post. Then it will probable hang vertically.
Bruce
Bruce
Yes, that sounds familiar and like it will work. Next day off is Wednesday so I hope to try it then. Thanks! Hal
   / Best way to vertically lift phone poles for fence #5
When I was setting my 16 foot post for my workshop I lift one end of the pole over the back of the forks on my tractor. With the forks close together to help steady it when it was vertical. I used part of the chain to hook to the post under the forks and do the lifting. The other end I used to steady the top of the pole with a simple loop to the top of the back part of the forks to keep the post from falling forward. After putting the post in the hole I would undo the lower chain and plumb the post and put my concrete around it. Then undo the top chain and get another post. Rick
   / Best way to vertically lift phone poles for fence #6
Or more likely - slide right off.
   / Best way to vertically lift phone poles for fence #7
We set corner post made from old utility poles all the time. Ours range up to 23 inches and we normally just use a nylon chocker.
A chain will work, but the choker hold better with no slip.
   / Best way to vertically lift phone poles for fence #8
When the crew set the steel posts for my solar panels, I snapped a photo. I don't know if it's of any benefit to you but here it is.
GGK
   / Best way to vertically lift phone poles for fence #9
Instead of hanging them, have you considered just elongating the upper 1/3 of the hole, pushing one end of the pipe over the elongated hole, then lifting the other end of the pipe with the forks close together as a cradle and just drop it in the hole? No chain needed.
   / Best way to vertically lift phone poles for fence #10
The problem will be the taper of the pole. If the cable slips it will loosen allowing it to slip further. What you need is a choker. You can do this with a chain if you use a slip hook. A slip hook has a opening larger enough to allow the links to slide through. You can also do the same thing using a logging cable.
Pre-Made Fse Choker 3/8"X12' (5 Lbs) | Chokers | Chains, Cables & Grapplers | www.baileysonline.com
3/8" Chain Choker System - Complete System | Chokers | Chains, Cables & Grapplers | www.baileysonline.com
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
2021 JOHN DEERE 624P WHEEL LOADER (A52705)
2021 JOHN DEERE...
ITEM LOCATION (A53084)
2012 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52705)
2012 CATERPILLAR...
2022 Toro 21in Hydraulic Walk-Behind Turf Aerator (A52377)
2022 Toro 21in...
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
