Best way to smooth out a yard
   / Best way to smooth out a yard #1
DCS
Angleton, Texas
JD 4310
What is the best way to really smooth out the hills and valleys in a yard. It is just to use the "eyeball to contact" method with a box blade or is there some "magic" implement I can use?
   / Best way to smooth out a yard #2
the box blade is pretty handy at moving dirt around. In some areas I actually took my tiller and dug it up then dragged it. Got it pretty level.
murph
   / Best way to smooth out a yard #3
For hills and valleys, (short of using a dozer) I would say a good eye would be your best tool. Spend some time marking the areas you want to cut and fill with some paint.
   / Best way to smooth out a yard #4
sence my septic system was installed i told the installer i would level things out as i wanted the seat time.
Ill have quite a few hrs with the FEL and BB. But as my property is so flat drainage (slope) is key so i dont wind up with low spots holding water :(
so as i start to find tune the grade we will use a builders level to shoot grades to make shure its going downhill somplace.
   / Best way to smooth out a yard #5
I have been doing the same this Spring, leveling out about 3/4 acre. I have been using a 6' rake and FEL. I bought 40 yards of top soil to fill in some sink holes, and level out some dips, etc.
Even with all my toys I mean tools it still is work. However no more blisters from the hand rake and shovel.
   / Best way to smooth out a yard #6
ya i was really surprised how quick my "little" 5' BB filled up. but it did make quick work of the ruts and REALLY uneavn ground in the 10 min i spent the other night.
I just need a turtle/rabit switch for backing up/going forward as backing up is PAINFULLY S L O W
   / Best way to smooth out a yard #7
Rototill. Two passes at right angles.
Don't overdo rototilling by making more passes since you'll just be breaking down the soil microstructure and ruining the natural soil drainage.
   / Best way to smooth out a yard #8
Harley rake. Find a place that rents one unless you can make a living doing this.
   / Best way to smooth out a yard #9
People have recommended rakes, blades, harrows and land planes to level my driveway but today I discovered that I already owned the best one. Dead flat and already compacted but only 2 feet wide per pass, just forget to raise your weight box before driving off. ;-)
   / Best way to smooth out a yard #10
I would have to say a Box Blade and a loader is about the best combination to resurface your land
New Land Honor 9200 LB Ratchet Binder And Chains (A53002)
New Land Honor...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
