Best way to protect from weld spatter?
   / Best way to protect from weld spatter? #1
Travelover
Elite Member
Washington
B7100
I need to weld a couple of nicely machined axle spindles into an attaching hub.
What would you guys do to protect the machined surface from weld spatter? I'll be welding close to the surface that the seal rides on, so I really need to protect this area.
Stick welding with a tombstone.
Thanks for any suggestions.
   / Best way to protect from weld spatter? #2
I once welded a hydraulic cylinder end and protected the shaft using duct tape.
Smelled a bit but no splatters stuck.
You could also wrap with a wet rag.
   / Best way to protect from weld spatter? #3
Cover it with a piece of pipe.
   / Best way to protect from weld spatter? #4
I just did the same thing. I just used a damp rag so i could pull it off right away after the weld. Be sure to do several tack welds so the stub stays plumb.
Didn't think of wet rags, but that is logical and cheap. :thumbsup:
I'll also look around for some old pipe that large.
   / Best way to protect from weld spatter? #6
I've had pretty good success with heavy foil wrap
A few layers and your off
   / Best way to protect from weld spatter? #8
Welder lit his torch without the oxy (lot of black smoke) and ran it over the hyd. rod cyl.. I asked what that was all about and he told me the splatter will not stick to the rod. It didn't.Learned something that day.
   / Best way to protect from weld spatter? #10
Put your old seal on it.
WORKSAVER RMB-325-PW LOT NUMBER 52 (A53084)
WORKSAVER...
John Deere 6120E (A50323)
John Deere 6120E...
Valvoline 80//90 Gear Oil (A53117)
Valvoline 80//90...
2008 Saturn VUE XE SUV (A53117)
2008 Saturn VUE XE...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2011 Wacker Neuson RD12A, 36" Double Drum Roller (A52384)
2011 Wacker Neuson...
