Best Way to Paint
   / Best Way to Paint #1
jayste
Veteran Member
"Sold the 1/4 of a 1/4 but still tractorin' "
2004 Kubota M4800 SU
Guys, I'm looking for suggestions for painting pipe. I've made some corner posts and gate posts out of misc. steel pipe and need some paint prep suggestions. Besides the usual wire brushing the rust scale off what do you guys do the make this paint stick and stay around a while. I'm thinking of using some oil base exterior primer and paint and probably going with a burnt orange color. Nothing fancy just common ag stuff. Need some input. Thanks.
   / Best Way to Paint #2
Hard to beat a good 2 part epoxy on utility metal...especially outdoors.
   / Best Way to Paint #3
They also make a product that will etch the metal, its something you would put on before the primer. It can make the paint stick better.
   / Best Way to Paint #4
Don't forget to "wash" off any oily residue. I like to use naptha because it's an excellent solvent and dries fast.
kj
   / Best Way to Paint #5
Don't know how rusty that steel pipe was, but if it was really rusted I'd use Gempler's rust converter as the primer and then paint over it. Avoids the wire brushing step.
   / Best Way to Paint #6
Use a product called OSPHO which is a phosfuric (sp) acid solution that chemically converts rust to another compound. There are other products that do the same thing. This will help get rid of the surface rusting / scaling and can be painted over.
After that any good oil based paint will do. Spray or roll on for quick application.
Rgds, tim
   / Best Way to Paint #7
You can also use Dairy line cleaner which contains Phosphoric acid for the original coating. It may be cheaper than some other products??:confused:
Do a Google on rust prevention. Lots of information.:thumbsup:
   / Best Way to Paint #8
When I purchased an older F350 from he company I work for it had a 10' flat bed with steel racks & a 1 ton lift gate. The racks & gate were pretty rusty. I took it to a body shop I've used before & they used a 'rust converter' product on it. The **** thing looked like new when I got it back (but my wife made me get rid of it anyway :( )
   / Best Way to Paint #9
follow primer rust removals above then, also when going about it get a good washing put (car wash mitt) one with good fibers lambs wool looking. and some long rubber gloves. put on rubber gloves, stick em in the mits and dip into the paint bucket & go to town fastest way to paint round fence pipes!!!
mark
2004 CAT 953C Crawler Loader (A47477)
2004 CAT 953C...
KMC 5610 (A53084)
KMC 5610 (A53084)
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2014 Ford Explorer AWD SUV (A53424)
2014 Ford Explorer...
2024 AGT LRT23 Mini Track Loader Skid Steer (A53421)
2024 AGT LRT23...
