best way to move big-ish rocks?
   / best way to move big-ish rocks? #1
zmjc
Eastern Ontario
L3800HST
Hi all,
I have a Kubota L3800HST with a 66" quick-attach bucket with a toothbar, and BH77 backhoe.
This is great for moving small and medium-sized boulders, but sometimes I want to move larger ones. By larger, I mean ones that two men couldn't lift easily - say a 2'-foot-diameter boulder.
The larger ones are too big for the backhoe to grab, and I don't seem to be able to get them into the loader bucket easily.
It might work if I used a ratcheting strap to get them into the bucket, but is there a better attachment for doing this? Maybe two not-too-long pallet forks?
What do you do?
- Mike
   / best way to move big-ish rocks? #2
Roll them on a hood off a truck, chain to drawbar and drag 'em.
Thanks, I actually didn't think of dragging them with a chain. Duh.
- Mike
   / best way to move big-ish rocks? #5
Make a rock boat. It's basically a sled. You can use it for all sorts of stuff. It's low to the ground so it's easy to load! Google rock boat.
The truck hood idea is a quick and dirty rock boat and would work great too!
Or google stone boat.
Thanks guys! A stone boat is exactly what I need...
- Mike
   / best way to move big-ish rocks? #7
Boulder sling, $10 in chain
The paint is to eliminate confusion when tangled.
Thanks for those pics! Very helpful.
- Mike
   / best way to move big-ish rocks? #9
Now that is great idea. Can be used with FEL or 3pt boom pole.
Wedge
   / best way to move big-ish rocks? #10
We always called it a stone boat. It is a sheet of iron curved up on one end with a chain bolted to it. Then it had 2x4 sides laid flat and bolted on to keep the rocks from slipping off. Works on stones you can't pick up with the FEL or are awkwardly shaped. Have had it on the farm since I was a kid.
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
2021 Deere 317G (A50120)
2021 Deere 317G...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
