Best way to get this new yard to come in
   / Best way to get this new yard to come in #11
Blb078,
Your pictures show an area that could really look nice. . but it's hard to tell if you have any slope issues. . especially front yard.
Here is what I did.:
1. Recognize that MO clay needs help growing go lawn. I'd suggest finding a compost producer in your area that can supply numerous loads. True compost is not farm/barn waste. The compost is a mixture of forestry grinding, leaf grinding, and 's percentage of straw/barn droppings (not pig). They are processed and then detour to cure for many months and then screened before delivery. Compost is not mulch. T is blazer than top soil and light in weight. . And it is like magic. You shallow till it into the ground and it alter how water and it deal with your clay. Some black dirt is good to add with the compost. You want 4 or 5 inches of compost/black dirt everywhere.
2. Insider putting in irrigation pipe before seeding. It's MO heat and a proper use of clay and compost will reduce how often you need to run the irrigation. . but it's really easy to do it now before seeding. (and it not complicated). And those pictures show you don't want o try sprinkling with hoses because you don't want to drag hoses over freshly seeded grass and you do want to water it everyday it doesn't rain till fully germinated.
3. If you are going to spray for weeds. . Do it now and use only weed killer (not weed and grass killer). Don't use anything that treats for pre emergent (like crab grass) and nothing that is SEASON long. You DON'T do this any later than 4 weeks prior to seeding.
Kentucky Bluegrass is heat tolerant and thick growing but it's 3 weeks to germinate and needs watering frequently till germination. You could also pretty plant 3 or 5 days ahead. . . some cheap annual rye grass to give the bluegrass some early shading and erosion protection (not perennial ryegrass).
If you use true compost as i've described mixed with black dirt. . You will not need to fertilize for 4 to 6 years at all.
   / Best way to get this new yard to come in #12
Spot application with a hand sprayer should be fine. Roundup/Glycophosphate is gone in ten days.
For the record (I made this error as well) Roundup is glyphosate, which you can get generically at Tractor Supply.
   / Best way to get this new yard to come in #13
I don't know what you had planted before the rain or what your expectations are for your lawn but a good seed choice for your area might be a turf type tall fescue. It wont be as pretty as a bluegrass or fine fescue lawn but it will root deeper, require less maintenance, less fertilizer and water input, and is very wear tolerant (your tractor wont tear it up too much). Tall fescue is especially well suited to the transition zone that you live in. Your choices are your own but if I were in your situation I would definatly be going with a turf type tall fescue.
   / Best way to get this new yard to come in #14
Lots of good advice here. I will summarize them all for you in this one post.
1 Let the weeds or whatever grow now - they will hold the world together until optimum time to plant.
2 Kill out lawn with roundup in the fall - only if your initial seeding is mostly weeds - I would still do it anyway. Kill it out about 10 days before the steps listed below.
3 Rent a harley rake/soil conditioner - the rotating drum mentioned earlier. You can rent one that goes on a skid steer or a dingo. Most places will have both. You can rent it on a saturday and take back on monday morning. You will have the finest seedbed you can get and the smoothest lawn in your neighborhood.
4 Soil sample
5 Erosion control after seeding. I prefer blankets, but straw will work. Get a tall turf type fescue seed and some triple 19.
Lastly, you can do nothing, get an aerator and go over your yard real well this fall, broadcast your seed and triple 19 and it will still look great.
2016 Isuzu NPR Landscape Dump Truck (A56858)
2016 Isuzu NPR...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2002 KENTUCKY 53FT TRI AXLE MOVING TRAILER (A57880)
2002 KENTUCKY 53FT...
Adams 6Ton Hydraulic Lime Spreader (A55315)
Adams 6Ton...
1454 (A57192)
1454 (A57192)
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
