Best way to get rid of 1 to 5 inch diameter inch trees to clear access road?
   / Best way to get rid of 1 to 5 inch diameter inch trees to clear access road? #1
PowerTracManiac
Central, Virginia
Power Trac 1460
Need to clear a couple access roads through my bug out property. Alot of 1 to 4 inch trees (oak and maple). I have the light material bucket and the 4 in 1 bucket and PT1460.
Going to try and just use the front edge of the bucket and dig into the ground slightly and lift and tear all this out as I go into it?
A little concerned about getting flat tires?
I think it will work on the smaller stuff but the trees that are around 4 inches and bigger may be a problem?
Any better/other suggestions?
   / Best way to get rid of 1 to 5 inch diameter inch trees to clear access road? #2
Don't cut them. That size stump will poke holes in a tire quick.
   / Best way to get rid of 1 to 5 inch diameter inch trees to clear access road? #3
if you have a helper and a lot of time one of these should work cheaply.
   / Best way to get rid of 1 to 5 inch diameter inch trees to clear access road? #4
I'd get a spare quick attach plate from PT, go to a used forklift seller (they are out there) and buy 1 heavy fork. Weld it to the quick attach plate. Push the fork under the ground and pop the trees out. I do that with 2" trees all the time with my little PT425 and PT's pallet forks. Don't pry with the end of the fork or you'll bend it. Drive it all the way in to the hilt then use curl and dump to pry. Should be a cheap attachment to build. QA plate is $350. Fork shouldn't be but that much. Welding is cheap. Your machine has ridiculous hydraulic power. Go slow.
   / Best way to get rid of 1 to 5 inch diameter inch trees to clear access road? #5
Hire a skid-steer or excavator with a brush mulcher. If there isn't much rock they can usually mulch right in to the ground so there is no stump left behind.
   / Best way to get rid of 1 to 5 inch diameter inch trees to clear access road? #6
I used a smallish dozer with the blade just shy of digging in so the blade hit the stump just above the ground. Kind of snow plowed them to the side. Not much dirt and easy to burn or mulch when it dries. Not sure how the compares to your PT though.
   / Best way to get rid of 1 to 5 inch diameter inch trees to clear access road? #7
How many, how dense together and over what distance? How much time do you have to accomplish?
Most of the ideas are fine for a few dozen, but if you're talking hundreds .....
   / Best way to get rid of 1 to 5 inch diameter inch trees to clear access road? #8
A Piranha tooth bar for the bucket of your machine will get the small ones,,,
I use a woodsplitter, and a couple chains to pull out 4" size stumps effortlessly,,, Hydraulic power beats working hard,,,
   / Best way to get rid of 1 to 5 inch diameter inch trees to clear access road? #9
CADplans,
Please explain how you pull out stumps with a wood splitter.
   / Best way to get rid of 1 to 5 inch diameter inch trees to clear access road? #10
CADplans,
I built my woodsplitter with connection points for chains,,
Put a chain through the tube, and connect the chain to the cylinder,,
Any woodsplitter will pull during cylinder retraction,, with the power of a 150 horsepower tractor,,
it will easily develop over 30,000 pounds of pull force.
New/Unused 13ft X 20ft Single Garage Metal Shed (A54865)
New/Unused 13ft X...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A53421)
2025 MS380R Mini...
2004 Ford F-250 (A53422)
2004 Ford F-250...
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
2008 INTERNATIONAL 9200I DAYCAB (A55745)
2008 INTERNATIONAL...
INOP-NON-RUNNING 2008 Peterbilt 340 Water Truck, VIN # 2NPRLN9X78M769162 (A54865)
INOP-NON-RUNNING...
