Best way to cut/maintain ditches?
   / Best way to cut/maintain ditches? #1
geneM
Can someone suggest what implement I could use behind a New Holland 2120 4WD for cutting ditches. I have maybe as much as 1000' of drainage ditch to cut and maintain. I'm just trying to control surface run off, not cut irrigation ditches so they don't need to be too deep or wide.
Thanks
   / Best way to cut/maintain ditches? #2
I'm thinking a dirt scoop would do the job for you. Your local TSC or Blaine's Farm & Fleet would have one, or Northern. They aren't very expensive, but they won't dig very deep either. You may have to break up the ground by making a run with a couple rippers down on your box blade to loosen things up first, then scoup out the dirt.
I've always thought there was a market for a two foot wide FEL with a deep bucket.
Cliff
   / Best way to cut/maintain ditches? #4
I used a rear blade swiveld and tilted to the max. This cut a deep ditch in no time. It is nicly sloped and now planted to grass.
   / Best way to cut/maintain ditches? #5
<font color="blue"> I used a rear blade swiveld and tilted to the max. This cut a deep ditch in no time. It is nicly sloped and now planted to grass </font>
I've recut some of my ditch, never done it from scratch, but I followed this same method. Angle the blade & tilt it, let the cutting edge engage the ground so that the corner of the blade makes the cut. I will say that the ditch work I did was started with an inexpensive swivel only blade and having to work in the ditch is what inspired me to switch to a much beefier tilt/swivel/offset blade from Corriher. Having the right blade made the job go much easier.
If the ditch is basically a dry ditch and only is wet during/after a rain, it should be tapered enough that you can grow grass on it and mow through it so once it is done, you shouldn't really have to maintain it other than mowing.
   / Best way to cut/maintain ditches? #6
I have the same Corriher blade as Bob and have used it the same way to cut ditches. At the risk of getting slapped by the safety guys, I have been known to stand on the blade for extra weight while my father drives the tractor.
2021 PETERBILT 567 DAY CAB (A53426)
2021 PETERBILT 567...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
2013 BRENNER TANK 10,500 GAL (A53843)
2013 BRENNER TANK...
2015 HINO XJC740 BOX TRUCK (A53426)
2015 HINO XJC740...
2014 Ford Escape (A50324)
2014 Ford Escape...
