Best way to cut a groove in a pto shaft...
   / Best way to cut a groove in a pto shaft... #1
Turbys_1700
Elite Member
Balls Creek, NC
New Holland t4.75
I had to upgrade our Howse PTO drive line shaft and slip clutch on our 10' rotary cutter...
The old slip clutch was in need of new friction discs and the nut holding the unit on was impossible to get off...
The new PTO drive live and slip clutch utilizes a bolt that passes through the yoke and thus requires a groove in the PTO shaft to accept the bolt...
The old PTO slip clutch utilized a keeper clip...
I think that the easiest solution is to utilize a side grinder and grind a groove in the PTO shaft to accept the bolt...
The bolt in the yoke is located so that it follows down the side of the PTO shaft...
If anyone else has any other alternatives I am open to suggestions...
   / Best way to cut a groove in a pto shaft... #2
Mill
Crap, 5 character minimum mur:
   / Best way to cut a groove in a pto shaft... #3
Turbis,
Your plan is what I would do. It would probably be a big job to take the shaft out and do it in a lathe. I would have the shaft turning and have something to rest my hands on to steady them. Take it slow and check your progress.
   / Best way to cut a groove in a pto shaft... #4
Maybe I mis-understood...
Is this a keyway type groove??
Or a groove that goes radially around the thing??
If the latter, then...
Lathe
   / Best way to cut a groove in a pto shaft... #5
are you sayingthe tractor pto stub does not have the groove?
   / Best way to cut a groove in a pto shaft... #6
This may require only a notch for a bolt whose centerline runs tangent to the shaft's OD. Since a lathe would groove all the way around I'd use the hand grinder. We notch plain-shank milling cutters for 'Weldon' holders & the result doesn't need to be all that pretty cosmetically. It just has to hold 'em. Test for fit as you go & don't remove too much stock. It should be as simple as you imagine it. ;)
   / Best way to cut a groove in a pto shaft... #7
almost seems a broach could be used..
   / Best way to cut a groove in a pto shaft... #9
I think a die grinder could accomplish this task with shaft still in gearbox.
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2011 JOHN DEERE 6115D (A52472)
2011 JOHN DEERE...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
Motorola RCH 3000 Remote Digital Radio Base Desk and Roadrunner MR8 DVR (A50325)
Motorola RCH 3000...
