Best way to clear land
   / Best way to clear land #1
Rustyrat
Maine
JD 2305 tlb
I live in Maine and I have a few acres to clear for a new lawn. Mostly small trees (2" - 12"), some bigger fir/spruce/maple. I realize that I may not be able to pull all the stumps with a CUT and backhoe. But after they are out and the big rocks are cleared what is the best implement to start leveling? Blade, box, or something else?
   / Best way to clear land #2
I would use a dozer to do the initial clearing and then a box blade with teeth should get you in pretty good shape. Ken Sweet
   / Best way to clear land #3
1) Stihl - cut trees, move to pile out of the way. Section as time allows, store for "seasoning" split before fall (use or sell).
2) Dozer stumps, rocks and general leveling.
3) Box blade, land plane and drag harrow to "finnish".
Basically, I agree with Ken.
   / Best way to clear land #4
ditto that.. hire a dozer for inital clearing.. if he's any good, he will leave it flat.
then you can use a box blad and drag to contour and plant grass seed and cover it.
soudnguy
   / Best way to clear land #5
What they said.
   / Best way to clear land #6
Dozer I would think would work well where soil is good and land basically fairly level. On rocky ground (like we have in Muskoka) an excavator works better, especially if it has a thumb. This is particularly true if you want to use any of the rocks for landscaping/retaining walls and if you want to bury some of the stumps to fill holes etc.
   / Best way to clear land #7
Checkbook. Easy on the back but harder on the pocket.
   / Best way to clear land #8
I agree to use a dozer but I would ad ..if at all possible have the dozer push the big trees over before you cut them and then cut the stumps off and burn them, bury them or haul them off but if you cut your big trees first and leave too short a stump you will need a track loader with a tooth bucket or an excavator in there to dig those stumps out and that gets expensive.
   / Best way to clear land #9
as already mentioned....
+1 for this
   / Best way to clear land #10
I'll be the odd ball and say excavator, especially for 12"+ roots. I have ran both and an excavator for this type of work will be faster, from my impression of what you're asking. A dozer will work but roots can be a job for a it. An excavator {something like a 307 cat} with a balde will run circles around a dozer. It is also easier to take out the whole tree{rootball and all} while it is still standing, IF YOU KNOW WHAT YOU'RE DOING !!!! Now if you're just worried about leveling simple ground then go with a dozer.
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52705)
2019 CATERPILLAR...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
2013 DRAGON ROLL OFF TRAILER (A53843)
2013 DRAGON ROLL...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
