Best Way to Clean up Zero-Turn Seat?
   / Best Way to Clean up Zero-Turn Seat? #11
If it doesn't clean up to suit you, maybe treat yourself to a new suspension seat?
This seat is a little weak on the suspension. I think my butt is the suspension.
   / Best Way to Clean up Zero-Turn Seat? #13
I tried everything from diluted bleach to Simple Green on my stained and mildewed boat seats, but the best and easiest solution was by far Starbrite Mildew Stain Remover. It works so well it's almost like magic. Now I use it on all my vinyl seats from motorcycle to tractor to boat. For light cleaning and protecting seats I use Meguiars #57 Vinyl & Rubber marine cleaner and protectant. It It leaves the surface a little grippy.
   / Best Way to Clean up Zero-Turn Seat? #14
What is the best product for cleaning up the seat on a Kubota zero-turn? The seat is some kind of tough plastic. Will Armor All do it?
Regardless how you clean it, I always rub Neatsfoot oil into my seats of vinyl, or whatever they're made of, to keep them from drying out and cracking.
   / Best Way to Clean up Zero-Turn Seat? #15
This seat looks like it has mildew in the little wrinkles they put in it to make it look like leather. I think I may have to use bleach.
Some Dawn and a couple oz of bleach in a pail of water will clean it up, kill the mold and mildew, without harming the material if you rinse completely after washing.
   / Best Way to Clean up Zero-Turn Seat? #16
I have not been able to find it in awhile now but Meguiars #39 vinyl cleaner I consider to be the best. Spray it on, wipe it off or you can use a little bit of brushing if REALLY ground in. Super easy to use and always sparkling clean.
   / Best Way to Clean up Zero-Turn Seat? #17
I’m a fan of Purple Power also so. I used to be a big fan of Bleach White but it changed hands to I think Blue Magic now. Armor All makes an Extreme Tire And Wheel Cleaner that’s as good as the old Bleach White.
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
2015 Infiniti QX60 SUV (A51694)
2015 Infiniti QX60...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2016 Chrysler 300s Sedan (A51694)
2016 Chrysler 300s...
