best way to clean a fuel storage tank
   / best way to clean a fuel storage tank #1
Tim_in_IA
Platinum Member
Eastern Iowa
Kubota B7610HSD, Mahindra 6500 4WD, JD 440ic crawler, 2 560 farmalls.
I have a 300 gallon tank on legs that was used for gasoline about 15+ years ago. It's been sitting empty (or mostly empty) the entire time. I'm sure there are rust flakes and other crap in there that I don't want in my diesel. What is the best way to clean this tank out for diesel use, and is it worth it or is it better just to find a different tank? I already know it is going to need a new filter assembly, filter, and hose, but is the tank worth salvaging?
Is there some type of neutralizing solution that I can put in it that will caputure the junk and treat the inside?
   / best way to clean a fuel storage tank #2
Tim,
There's an active thread on this subject over at CBN.
Take a look here
Brian
thanks for the link. I make it over to that sister site every so often but never seem to stick around. Sounds like old used tanks are a bad idea? I'll have to see just how bad it is before I put a lot of investment in it. Mine is welded to the uprights so I can't really roll it around to coat the inside.
   / best way to clean a fuel storage tank #4
I'd sleep better at night with a new one....
Generac S/A Towable Light Tower. (A52377)
Generac S/A...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A52377)
2019 Allmand...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
GooseNeck Trailer (A52377)
GooseNeck Trailer...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
