Best way to chain a stump???
   / Best way to chain a stump??? #1
Tororider
SE Michigan
JD 4310
Is there a best way to chain a stump to pull it out? I have heard wrapping it from top to bottom and then back up so that it pulls and tightens on itself. Is there a special logging chain that would work better?
   / Best way to chain a stump??? #2
I've seen logging chain with links that are square in cross section rather than round. Supposed to bite into the log rather than slipping off. Sounds good in theory.
I did a google search before posting this reply, but didn't find what I remember. I'll look some more and repost if I find it. :)
   / Best way to chain a stump??? #3
I use a 6 foot chain with 1/2 inch links. On one end I have a round link that is big enough to slide a hook and chain through. On the other end I have a hook that will hook on to a 15 foot log chain. I wrap the stump/log with the short chain, slide the hook through the round link and fasten the hook to the 15 footer. As I put tension on the chain the short chain snugs up tight to the stump/log and in most cases locks on to the log or stump until tension is released. It is very easy to fasten and very easy to remove after the log/stump has been removed. There is a name for the short chain that I use but don't recall what it is.
   / Best way to chain a stump??? #4
We call them chokers and they are usually made of cable aka wire rope.
   / Best way to chain a stump??? #5
I usually leave as much sticking up top and just wrap a chain around the top upper part and wet/soak the ground really good and just pull them out, like pulling a nail out of wood. I don't think that is what you have, food for thought next time
and the choker method is the best
I wish I could have been more help to you
Jim
   / Best way to chain a stump??? #6
Chokers are a lot easier, but you can also improvise and use a figure 8 or double wrap that will usually hold
   / Best way to chain a stump??? #7
I would just wrap the chain around the top of the stump so it makes two full loopes and hook the chain back on itself. As you apply tension on the chain it will just get tighter and tighter and when the tension is released it is very easy to take off the log. I use 3/8 tow chains with the grab hooks on the ends. It is a lot cheaper than buying the loggers choke or the special logger's hooks. Also the chain is a bit more multi purpose that way. I only cut about 3 cords of wood each year and very (very) seldom pull on stumps so the extra time it takes to make the loopes does not matter to me.
   / Best way to chain a stump??? #8
What size tractors are you guys using to pull stumps? My Kubota L2800 only weighs 2,300 pounds or so and all four wheels just turn when I hook onto something like that.
   / Best way to chain a stump??? #9
I dont pull stumps, its easier to pull whole trees. As soon as it leans over, the gravity of the crown takes over and rips off the roots.
Once its down, i use the loader to chop off some more roots, saw the branches of the log and then attach a chain to the far end, to twist it around in a circle untill all roots are broken. with a downed tree still attached to it, you have a lot of leverage to twist the stump off its roots
Started pulling stumps tonight. Worked pretty well, just wrapped it a few times and then wrapped it back on top of itself and it tightened down when under tension and most of them pulled right out. There were a couple 8-10 inch diameter ash trees that didn't want to come out, I think I may have to use a sawsall to cut some of the bigger roots to get those out, but for the most part they popped right out.
Dabear,
We have a JD 4310, and we had to work at it sometimes, but wasn't too bad.
2013 DRAGON ROLL OFF TRAILER (A53843)
2013 DRAGON ROLL...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
Light Tower (A52377)
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2430 (A51248)
2430 (A51248)
