best way to add stability to YM2000?
   / best way to add stability to YM2000? #1
panthercoach
Alabama
I'll soon be buying a YM 2000, rotary cutter, and finish mower. I have some hills and uneven terrain and want to make tractor as stable as possible but not make it so heavy as to mar the ground badly. Between adding 200lbs. of front weights or filling the tires, which would be most advantageous? I'm not sure how much weight would be added by filling tires. Any thoughts?
   / best way to add stability to YM2000? #2
Consider a ROPS. Anything you do to help avoid rollover, sideways or rear, becomes useless if it actually happens anyway. At that point the ROPS may save your life.
   / best way to add stability to YM2000? #3
I'll second the ROPS. I have a YM2000 and have added both front weight and filled the tires to about 75%. Also, turning the rear tires to the outward most position will help. More than anything common sense and thinking about what you're doing will keep you out of trouble. By the way, you should also get an overrun clutch for use with the mower so you don't lose control of the tractor. Good Luck!
The tractor I'm looking at has ROPS and I have already planned on the over-running clutch. About how much weight does filling the rear tires of the 2000 add?
   / best way to add stability to YM2000? #5
</font><font color="blue" class="small">( The tractor I'm looking at has ROPS and I have already planned on the over-running clutch. About how much weight does filling the rear tires of the 2000 add? )</font>
There's allot of threads here about filling tires.. I plan on doing mine sooner or later, but I also perked up a bit when someone was talking about home made wheel weights not long ago.. The weights can be removed easier than the water.. I cant help with the advise because I havent done it, but I recomend a search for these topics too...
As for the O/R clutch... Make sure you spring for the quick disconnect.. Well worth the money.. You only need it with the cutter, so if you have a tiller or anything else you'll need to remove it(not so easy if its not a quick connect)..
   / best way to add stability to YM2000? #6
</font><font color="blue" class="small">( About how much weight does filling the rear tires of the 2000 add? )</font> 130# per wheel w/calcium
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
Stihl KM 130R String Trimmer and Edger (A49461)
Stihl KM 130R...
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
2020 KUBOTA RTV...
GENERATOR HOUSE POWERED BY TWIN (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
3-Point Bale Spike and Kroyker Loader Combo - Includes Trailer Hitch Adapter (A51039)
3-Point Bale Spike...
