Snow Attachments Best type of snow plow...
   / Best type of snow plow... #1
Yooper3830
I have a 3830HST and I'm getting ready for my first winter with it. I have a driveway that is has a circle in the middle and is roughly about 100' long and 80' wide at is greatest point. I've plowed with my ATV for several years but in heavy snow the blade rides up and it's useless.
A friend has a 4340 and he bought a used truck plow and fabricated a quick attach and uses it on his FEL with the bucket tilt hydraulics operating the blade angle hydraulics.
I'm leaning more toward a rear plow. I have a 72" Befco backblade. I was thinking about finding (where?) some 1" rubber wear bar and using the backblade to plow in reverse (I know - sore neck time). I have blacktop that I want to protect so a metal wear bar isn't an option.
I work at a metal fab shop so I can be creative if I want.
Questions:
1. with a rear blade, does pushing backwards work better than plowing forward? My guess is yes because you're not packing the snow as you drive on it.
2. Any idea where I can get rubber wear strips?
3. Has anyone built basically an oversize box blade for the 3pt designed for snow? My drive is short enough that I could probably "capture" the snow in a box; I don't necessarily have to have it roll off the plow.
4. Anyone have any FEL based plow ideas the really work well fro them?
Thanks!
   / Best type of snow plow... #2
I bought a rubber cutting edge for my FEL mounted blade at this place. Click Here It's the last item on page.
Here is a thread where a edge was put on snow blades. Click Here There are some pictures of my blade.
I have a Curtis blade on my FEL. It works great. Here is a link to my photo gallery on TBN. It shows my blade mounted on FEL.
My old Farmall had a Myers truck blade mounted on it. It worked very well and a lot cheaper than my Curtis blade.
   / Best type of snow plow... #3
I don't personally have a plow, so I have no experience with this, but several threads on this forum have discussed using strips cut from rubber mats made for horse stalls.
If you do a search for blade edging or such, you should find a lot of references to this.
Terry
   / Best type of snow plow... #4
Urethane wear strips/cutting edges are even better than conventional rubber...check 'em out here
Good Luck,
Steve
   / Best type of snow plow... #5
I made awear strip for my small 54" front blade on my JD4100 out of UDPE - Ultra-high Density Polyethelene. Its a very abrasion-resistant plastic that can handle the cold.
I made the strip out of 1/2" by 4" beveled on both sides so I can flip it over when it wears out.
After last season, I figure I will get another season out of the first edge and then have to flip it over next year.
Pictures in the original post/thread:
54" to 66" Blade extension & Wear Strip
- Rick
   / Best type of snow plow... #6
</font><font color="blue" class="small">(
Thanks!
)</font>
Using the three point hitch in reverse, is not a good idea. You are putting the load on in the opposite way the design envisions. In the case of powder it doesn't seem to be troublesome, but with heavy wet snow it is possible to have problems with the lift arms rubbing on the inside of the tire if your sway adjustment isn't perfect. I would imagine you'd have more of the light dry snow in the upper pensinsula than wet, but it would probably be in greater volume than here in the mid south. I plow forward, limiting the rear blade height with position control so it never actually touchs the surface of my driveway. The tread width of my tractor is narrower than that on my trucks, so the snow packed by the tractor tires isn't much of a problem. Of course good snow tires help considerably with the little bit than packs under the truck tires. We have more trouble with freezing and thawing than yoopers do, so mud is a big consideration here. Good luck. /forums/images/graemlins/grin.gif
   / Best type of snow plow... #7
I've ben using an 8' pickup plow on the 3pt on my Massey 135 2wd tractor for 5 years. THere's a homemade triangle frame that uses the lower arms and an adjustable top link. Adjusting the link changes the angle of attack of the cutting edge. That's useful depending on snow, ice, light, heavy, etc. I use double ring chains on the loaded ag tires. Two problems arise: first is how slow the lifting is when cold - it takes about 1/2 hour to warm up the oil to get reasonable response time. Second is that you can only lift so high, not enough for high banks that we sometimes need here in western Mass. However, the tractor turns around basically in its own length, will push almost anything, and is easy to raise slightly for pushing snowbanks back over the lawn. The light front end makes turning a snap. Ya do get sore in the neck though.
My new machine (1993 2120 NH fwd) has a Fisher pickup plow on the quick-attach with the power angle run by the remote valve. Just got it so haven't tried a winter with it, but look forward to facing the front end for a while. That rig dangles the front of the plow from a chain, so you adjust the angle of attack by the height of the loader.
I don't know about abnormal wear on the 3 pt arms. I use rigid braces to homemade pivots bolted to the bottom of the axle housing and aligned with the 3 pt. front mounting pins, so I don't have much side sway. That works pretty well for most situations. My rear plow was just a cheap way to move snow, but it worked pretty well, just hard on the neck.
   / Best type of snow plow... #8
</font><font color="blue" class="small">( Has anyone built basically an oversize box blade for the 3pt designed for snow? My drive is short enough that I could probably "capture" the snow in a box; I don't necessarily have to have it roll off the plow. )</font>
I used some scrap plate steel to box in the ends of my 6' Howse blade. I braced them diagonally in to some existing holes. It really cut down on the amount of time it takes for me to clear my drive...no more chasing little windrows back and forth across the big area. /forums/images/graemlins/cool.gif
   / Best type of snow plow... #9
I would try using the rear blade with a wear strip as suggested. I've used a 6 foot rear blade with liquid filled turfs on my B2910 on a gravel drive about 200 feet long (and level) driving forward. This leaves the FEL for clean up or other uses. With a little practice you don't need to turn around to watch much. I have rotated the blade 180 degrees when the ground isn't frozen solid and driven forward. Of course you don't have that problem or kicking up some stones with blacktop. I'm looking for skid shoes or something to keep the blade up a bit. Packing the snow really hasn't been a problem and I'm careful to lift the blade before turning too much. You may get a bit more snow however.
Good Luck
2009 Hartland Camper (A50514)
2009 Hartland...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
Hays LT1 Tender (A52128)
Hays LT1 Tender...
Wolverine Quick Attach Hydro Slide Pallet Forks (A50514)
Wolverine Quick...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
