Buying Advice best tractor with available backhoe
   / best tractor with available backhoe #1
jacobsdaddy06
NW Arkansas
MF1240
ok looking into a tractor no smaller than 25hp that has the best tractor/backhoe combo, have 10 acres thats gonna need some things done as far as digging so I figure Im gonna be money ahead to go ahead and get the backhoe with purchase, will also be running a hog, blade, usual 3pt attatchments.. all residential use so just needing something for myself... (digging will consist of tree stumps, ditches, pond work,etc..) thanks for all replies
   / best tractor with available backhoe #2
I have 9 acres and absolutely love my JD2520. JD is replacing the model 46BH with a new model, the 270. It has a shorter sub frame that does not interfere with a belly mower and you do have to remove the 3PH arms to mount the backhoe. I believe the new backhoe will be available in the spring. It is a very strong tractor, JD is very conservative with ratings, the loader is spec'ed for 800 pounds, but I have lifted close to 1100 lbs.
attachment.php
   / best tractor with available backhoe #3
Take a look at the B-series Kubotas. They have one of the cleanest looking factory backhoe packages I've seen. The hoe is mounted in close to the tractor and uses a swivel seat like on the larger units. The Kubota backhoes are also pretty powerful for the size, lots of bucket breakout force.
   / best tractor with available backhoe #5
I bought a Kubota BX25 this spring and have put 300 hrs on it to date. I am very pleased. It is a real work horse. They all have the 0 down 0% deal, but in my area Kubotas are $1500 less that a Cub Cadet or JD. Buy American won't fly as all the compacts are foreign made. JD uses the Yanmar engine. JD was out for me as the closest dealer is 60 miles away. My local mechanic had a CC in his garage stripped down as he was replaceing some major frame parts the owner had twisted up. They are stamped sheet steel shapes where the Kubota has much heaver structural hot rolled shapes. That and the fiberglass body parts convinced me the BX 25 was the best deal all around. I have used the backhoe probably 70 of the hours. It has great pull out power on the bucket curl for working in tough dirt and pulling/cutting roots on stumps. I have dug out 6 alder stumps with 10" trunks in good time. It is not something to make money as a production machine but I use it only on my own place. The 8" bucket works better on stump pulling than the 12". If you can afford the extra $400+ get the 12" bucket too. I wish they had a large grading bucket w/smooth edge that fits the pin arrangement as I have a lot of ditch cleaning and slope dressing to do. Working on some ideas to make something this winter to keep me busy. Wish I would have bought the mechanical thumb also.
   / best tractor with available backhoe #6
Look at a JD 110 TLB.
The JD110 is a dedicated construction grade TLB, the loader and backhoe are permanently mounted and it does not have a 3PH or PTO. Very nice, but not the Swiss Army knife a property owner is looking for.
   / best tractor with available backhoe #7
We've been very happy with our NH Workmaster 55 with backhoe. Slightly smaller version of the backhoe is available with the Workmaster 45.
By the numbers, the bucket digging force is the highest for any of the major brands (JD, Kubota, MF, Kioti NH). Subframe mounted.
   / best tractor with available backhoe #8
Based on your requirements, there are a number of tractors that can be equipped with a BH and do the other tasks you have listed. Do you have a colour preference? Some people will not look at a blue, green, orange, etc. A couple have posted a Deere and NH, I have a Kubota MX5100 with the BH92 so that will give you another possibility. I think first you need to decide what your budget is and what dealers you have close by or are you considering used? Just in the Kubota family, there are several models that would fit your needs most likely and they do come with BH's. There is also Kioti and I'm not sure but I believe Mahindra (sp?) may have a BH as well. All manufacturers have different ways they attach a BH so you may want to look at that as well because if you are removing it and putting it back on frequently, you want it easy. I liked Kubota's design and it takes me minutes to do both. You will also want to try different tractors for look and feel as everyone has their own personal tastes.
A BH definitely adds to the cost of a tractor and I know many do not opt for this attachment and instead rent a mini excavator. Based on my needs and considering I had one before on my Kubota B20, I decided the money was worth it as I have a lot of stumps to remove, a lot of rocks and don't have the means to go rent a unit quickly and transport. Below is my new baby and I am very happy with it so far. The BH has plenty of power and pulled a 26-28" white birch stump with little difficulty at 1700 rpms.
   / best tractor with available backhoe #9
Is it me or does the right stabilizer arm on the NH Workmaster 55 with backhoe
look bent?
Devildog
   / best tractor with available backhoe #10
look bent?
Devildog
Both are bent. Comes that way from the factory. (That picture is from when they dropped off the tractor: 3 hours, Backhoe fresh from the factory)
2010 Chevrolet Silverado 1500 (A55973)
2010 Chevrolet...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A56435)
BOSS 990 Fuel...
2015 Chevy Cruze Sedan (A56859)
2015 Chevy Cruze...
2021 Ford F-450 (A55973)
2021 Ford F-450...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2006 Cummins DGBB 35kW Standby Diesel Generator (A56857)
2006 Cummins DGBB...
