Best tractor list
Status
Not open for further replies.
/ Best tractor list #41
Oh, I never claimed to be the wise old sage here when it comes to tractors. I'm sure there are many guys here who had been working on tractors for decades before I was ever born. I have, however, turned enough wrenches on equipment to know what is quality and what is a turd painted to look pretty. I've actually, on several occasions, made positive comments about Mahindra, so relax. Mahindra is not a new company nor one new to manufacturing tractors. I would not at all be surprised to hear that someone was impressed with one of them.
I won't name any names, but even though I'm not a betting man, I'd still bet that many of the tractors you consider 'high quality' are nothing than extremely poor quality wannabe's with a shiny paint job and some jazzed up sheet metal. Underneath is 20 to 30 year old technology and likely 2nds at that. You want to compare Toyota and Kubota to some of the other off brands that are new here, but that comparison just doesn't stand up. Toyota and Kubota never granted franchises to roadside yard barns and allowed the dealer to carry zero parts, have zero training, and only stock one or two of their units. Basically, they didn't try to sneak in the back door. That is exactly what many of what you consider "quality" offerings is doing. You have simply fallen for their ruse.
/ Best tractor list #42
What amazes me is that rather than pointing out other bits of good design or bad design found on tractors so that a thread about BEST TRACTORS can stay on topic, it seems like there is a lot of arguement over a simple observation about the (opinion) of the poor placement of the 3pt lever.
GeneD14 said:
Most of the time when I am using the 3 point control to hook up an implement, lower the brush hog into the grass, or lower any other implement I am turned around looking back at the implement. If the lever is along side the seat: good. If the lever were in front or down low: bad
While some may feel they are be able to operate it under all conditions, GeneD14 and Soundguy certainly understand the observation and GeneD14 obviously understands why it is a poor (opinion) placement.
So to get onto the topic of BEST, let's consider the placement of the "cruise control" on some of the newer John Deere tractors. It is on the right fender and can be actuated with your thumb while your hand is on the 3pt lever. You don't have to take you eyes off the path of travel to find it, you can feel it. I have a dash mounted cruise control on one tractor and it is behind the steering wheel requiring a reach around, its a traditional location and not a bad one, but not as nice as the JD location. On another I have a mechanical cruise control and it is the worst of all I have seen.
Soundguy said:
if that is the HD bucket.. I sure would hate to see the light duty one!!!.. Looks like those implements made for lawnmowers.. etc..
That is my point, when you see a bad feature or design it is pretty obvious. That bucket is on what is supposed to be on a H.D. tractor based on what the sales guy told me. The top lip is a simple fold. It is completely unreinforced along the top. Compare that to some of the other brands buckets that have heavy wall square or round tubes welded full length for top rigidity. The bottom edge (not shown in the photos) was a simple cutting edge, but there was very little on the bottom to prevent wear through, compare that to the buckets that have several full depth wear/skid strips welded from the cutting edge to the back of the bucket.
/ Best tractor list #43
Farmwithjunk said:
As the "AG tractor" evolved, the also-rans fell off the edge of the earth. I'd bet the ranch that'll happen with some of these 3rd world bargain brands in due time.
What tractors are made in the 3rd world countries? China, Korea, India and Japan are not third world countries, and that's where a lot of under 100 hp tractors are coming from today.
Many of the older companies were merged with other companies over the years, and names were changed, but the products were often times absorbed into the other company's line. It wasn't the product that doomed these companies as much as it was mismanagement and poor marketing.
The tractor market and the automarket are very similar. In the 70's Japan automakers like Honda and Toyota entered the U.S. market, as did Kubota. People didn't think they would last, but the not only lasted, they thrived.
It hasn't been that long since Hyundai, Kia and other companies entered the US automarket, following closely behind them we have seen companies with similar roots enter the tractor market.
In regards to Ag tractors, it is just another change in terminology. There haven't been just tractors for at least five decades, or more. It used to be that there were row crop tractors and utility tractors, with the row crop versions having a higher ground clearance for cultivation purposes, and the utility versions were lower to the ground for more stability.
The lines between the CUT and Utility (Ag tractors if you will) are beginning to blur more and more as the size of the CUTs increase. My 40 HP CUT is larger than a lot of the older used utilities I looked at, and with CUTs in the 50 HP range becoming commonplace I am seeing a lot of farmers trading in their 135 Masseys, 3000 Fords, etc., and going with these larger CUTs and loving them.
/ Best tractor list #44
Keith_B said:
KB, I tried out that model of tractor when I was shopping, and one does not have to bend over to reach the 3 pt valve, to raise and lower the 3PH. If you look at the pic it shows the 3PH valve lever is just below the edge of the seat when in the down position. The seat will lower as weight is put on it decreasing the distance. I've driven about every major brand of tractor there is and found it to be neither more nor less comfortable to operate the 3PH on this tractor than on all of the other brands.
Keith B, I totally agree with you, hence the "bend over-silly" in qoutes in my post. I owned a 4940 for about 6 months and found it to be a very comortable tractor, in my opinion. Maybe I have long arms? I also liked having the loader valve set back closer to the seat, even though it made exiting that side of the tractor more difficult.
KB
/ Best tractor list #45
Dargo, believe me I have used enough tractors to know what is a quality tractor and what isn't. I pretty well listed in a previous post the secondary companies (at least in the US market) that I consider putting out a quality product at the present. Which of these are you proclaiming isn't a good product at the present time?
I must point out that my not agreeing with Bob on his opinions not being facts does not mean that I do not share those opinions about the tractor in his photos. You will also note that I do not have it listed in my post above, I also do not think the company will have the longevity necessary to provide service in the future as they do not appear to be dedicated to success of that tractor line.
/ Best tractor list #46
Brent that is an excellent point. But let me expand a bit. Most of the tractors in the market today seem to have quality engines that are of modern design (but that may be due to EPA mandates). However,when other factors are taken into account, I think some tractors really stand above others for design and features. You really hit something when you said "underneath is 20 to 30 year old technology" because that is a very true statement. Take a look at the NH TC30, JD 790 or the Kubota L2800 gear machines. Those are great examples of 20 year old technology from "Big 3" manufacturers. But many of the newer brands also lack modern ergonomics. The photos I posted previously certainly show some problem points.
While this thread is about BEST TRACTORS and not about 'budget machines' it does make sense to look at the budget machines so we can see the shortcomings, because that helps illustrate why some other designs are better.
Take for example simple 4x4 shift and then compare it to the "sensi track" system that is on some of the New Holland machines. No way to compare them, and no legitimate way to claim that anything else is as good. Sensi Track simply sets the highest standard. Or look at JD's LoadMatch technology, again, it is the highest standard. The NH's rabbit/turtle switch is a great feature, not quite as good as LoadMatch, but still better than other offerings, which basically don't have a feature that is similar.
KrumpsBros said:
I owned a 4940 . . .
KB the tractor in those photos was not a 4940 or even remotely that large. And if you could get out the right side of the tractor in the photo then you are a real acrobat because the only way to do it would have been to go over the top of the loader valve/lever.
/ Best tractor list #47
KB
I'm only 5-8 and have average arms for my height, so long arms isn't a reason for me being comfortable with the operation of the 3PH lever. I actually found it more comfortable than the tractors where you have to reach back in order to work the lift. Those work great when looking over your shoulder, but when working the lift while looking straight ahead are a bit uncomfortable.
I thought the loader valve being set back closer to the seat was a plus on the tractor, as one didn't have to extend their arm as far to work the joystick control. My biggest problem with the tractor, and it is one I had with a number of the CUTs I tried out, was it didn't have enough weight for the uses I need a tractor. I also didn't get a sense that the parent company was giving the dealer enough support to make them successful in the long term.
/ Best tractor list #48
It looked like the 3940 that I tried out to me.
IMO, a lot of the features being touted as setting the "highest standard" are more about making the tractors fit into a niche than anything else. The manufacturers are putting these features in for those who are entering the market and aren't experienced users. A lot of tractor owners, especially those that are long term users, do not need load match or a rabbit/turtle switch. Most guys I know don't even think about what gear they are using for a job, they'll put the tractor in the right gear from the beginning automatically without thinking, and without having to begin pulling then have a computer tell the tractor what it is supposed to be doing.
These conveniences, while nice for a lot of people, aren't must have items for everyone. Personally I enjoy having the 12X12 shuttle on my Mahindra just like I enjoyed using the old triple range Case 430 my late father-in-law owned, or the 8 speed Ford 4000 he owned. I derive an element of pleasure when I've got the plow running deep and the tractor purring just right as I break the ground and smell that fresh dirt.
/ Best tractor list #49
Pssst, Keith. Bob put you on his "ignore" list. He won't see a word you have written. Your above post will be for naught.
/ Best tractor list #50
Pssst Dargo, thanks for the heads up. But I suspect that this post did not discusss the topic of BEST TRACTORS but instead probably just tried to pick my posts apart. I really don't understand why people get their undies in a bunch when attempting to discuss tractors in an objective manner.
But let me add a bit. There are dozens of innovations that people do without every day. Its been said before, but when electric windows were an option on cars (they called them electric windows back then, but now we call them power windows) people said they wouldn't buy them because they were "just another thing to break." I suspect that some folks look at the new digital displays on the Kubotas and Deeres are say the same thing. Heck they probably say "my Pappy didn't need that so I don't either" but then go look at the real farm tractors and you see GPS units and ground sensors, and all sorts of complex do-dads that people don't need...unless they want to remain in the modern age of agri-business.
Again, just staying on topic, this thread is about BEST TRACTORS not "just getting by with old technology and aging design."
Innovative designs that are easier & faster to use, like the curved arm loaders are another design feature that are not gimmicks. In fact a well designed and innovative feature makes the tractors more productive.
So next time someone says SensiTrack is just a gimick, take his tractor, shift it into 4wd and turn some circles on his nicely groomed lawn. Then do the same with a SensiTrac equipped NH. Or pick up a Bi-Speed front end equipped Kubota, its different than SensiTrac but the end result is similar. The turf remains in tact while the regular 4wd will tear the turf. And while not everyone mows their lawn with a tractor, it doesn't change the point. The tractor is just as good when used by a professional landscape contractor, or golf course or park.
Now one thing that Chris (Soundguy) pointed out earlier in the thread is that there are all sorts of different uses and Chris and I use our tractors differently and in different climates. But while Chris is a gear guy, and I'm sold on HST, we can both agree that some things are simply bad design and other things are simply good design, even if we don't use that tractor in that specific application.
Heck with the way some people toss around logic, I'm beginning to wonder if all cars are the same. A Yugo is just as good as a Chevy, after all they both have and engine, a steering wheel and headlamps . . .
/ Best tractor list #51
Hello BobS,
You have made some great points about the layout of that model tractor. Hopefully people don't get the wrong idea about that brand of tractor. They do make nicer models than that one. I tried out the blue version of that tractor and found the 3pt hitch lever actually lays right up against your leg. Way to tight for me. I'm 5' 8" at 180 lbs. Still to tight and cramped for me. The major problem or poor design of that tractor {according to me} is the fuel tank behind the seat. I could not even see the end of the 3pt hitch arms when they were lowered. I can't imagine trying to grade with that tractor. The statements you made about "feeling" for the correct levers while operating are exactly why I picked the tractor I did. Shift levers are on the left while the 3pt hitch lever is right beside my right hand at a comfortable position and the view behind me is clear with no fuel tank blocking my view. Just like you said earlier, I bought my tractor based on what I needed to do with it and how productive the layout of the controls were. Very good advice.
/ Best tractor list #52
I am well aware of his move. That's Bob's way of saying he was wrong and I was right on the fact/opinion issue without his actually admitting it publicly. He calls me silly and puts me on his ignore list, it is like a little kid having a temper tantrum and stomping off to sulk. Plus, the odds are that he didn't actually put me on his ignore list, he just said he did so he could sulk.
Bob's one of these guys that views the world in two ways, his way and the wrong way.
/ Best tractor list #53
The cream always rises to the top.
Hard to argue with that statement.
The real question is, who will be making the cream and what's IN the cream. It's no secret that almost all major brands are starting to use components made in 3rd world countries. Many are assembled outside the U.S. such as in Mexico? I see this practice as a growing trend, not a decreasing one.
As with nearly anything you purchase, there will always be "choices" balancing procduct and price. Then there are always "markets" to sell to. I'd say the real value of the procduct (or lack thereof) lies solely with the purchaser. What's that old saying?...one man's junk is another man's treasure...
/ Best tractor list #54
Donnyj said:
You have made some great points about the layout of that model tractor. Hopefully people don't get the wrong idea about that brand of tractor. . . Just like you said earlier, I bought my tractor based on what I needed to do with it and how productive the layout of the controls were. Very good advice.
Donny, I forgot about that point but I do have a photo. In fact another bad (opinion) design, at least of this version, is that the SMV sign must be removed to refuel the tractor (fact).
But I was not trying to pick on this particular tractor, nor even this brand. In fact if I was better at using Photoshop, I would likely have changed the color to purple, yellow or pink or something that would have made it harder to identify the brand. And I've even pointed out problems with Big3 machines and my own machines.
The point of my post, clearly missed by some folks, is that there are some design features that are clearly inferior to others.
I'm not sure it matters who makes it or what country it comes from when we are talking about the BEST. I think it is more an issue of who innovates the features that are truely useful. Some features on an Indian tractor may be better than an American tractor but worse than an Italian tractor, etc. Your point about value is well taken, and well made, but there are some things, when discussing BEST, that are clearly superior. . . not that everyone can afford it, but the thread is not about who can afford what it is about BEST.
/ Best tractor list #55
Keith, I'll admit that I do have a few people on my "ignore" list. While I cannot speak for Bob, I can tell you why I felt obligated to place a few on my ignore list. Basically when a guy proves to me (usually over and over again) that he cannot possibly add anything of any value to a conversation, when he constantly offers up wrong and, often dangerous advice, and when I can never gain any useful information from that individual, he goes on my ignore list. It's a fact that most states have closed their "state hospitals" due to lack of funding and sent some mentally unstable people out into the general public. Fortunately, it's not too many, but I feel a few have found their way here; which is fine, except I have not the time nor patience to debate someone with the mental capacity of a three year old.
/ Best tractor list #56
I looked at all of the major brands last week except JD. I left the dealer of pictured tractor a little unimpressed myself. Whereas I liked the beefiness of the tractor that loader mount is (IMO) ridiculous. It is way too limiting on the right side. If you can worm your way around the control then you would either be extremely skinny or wounded from the gashes received.
In terms of "best tractor", I'm having a hard time. I want a 25-30 hp, 4wd, hst, fel, capable of utilizing a 6' rfm for maintaining my 8 acres of relatively flat property. Any suggestions are welcome please explain why in your opinion. The Kioti dealer was the first to say a 25 hp (ck25) would be fine with the 6' rfm. I think weight should be an issue with the fel.
/ Best tractor list #57
Dargo, I know what you're saying about mentally unstable people. I own a website with a messageboard, and have had to deal with users that threaten other users.
All of us are here because we love tractors and using them. which means we all have things in common.
/ Best tractor list #58
:( Me; beigng a sorta simple fellow relegated to the lower drawer in most capacities just can't undertsatand what all this discussion about.
Seems to be a lot of controversy but am not really able to ascertain whats it about. Maybe a bad day or something like that. Or is it just plain foolishness?
With all those quotes etc. one gets to read foerever but it's just repition. Sure builds up the useless post number though.:confused: Just like this one!:(
/ Best tractor list #59
Keith_B said:
...and have had to deal with users that threaten other users.
Holy smokes man, you don't think I'm trying to threaten you by any means, do you?! Sure I can get serious, but I also play the jester at times and, if you find the right thread, I am the the one being picked on (in good humor....I hope :)). Heck, I think if you can't laugh along at yourself at times you have other issues.
But, we are off the "best tractor list". If you want to place a "for the money" qualifier to the list, I would submit a deal I seriously thought about and missed while I waited. A local Rural King had their largest model, an 82 hp Cummins powered unit with a cab and A/C listed for a super sale price because of some sheet metal damage. I've tried to put it out of my mind because I think I should have bought it, but I think they ended up selling it for $14,995 with a matching Koyker (sp?) loader. It honestly was a very heavy tractor. I drove it around their lot (several times), and it worked fine. The paint was really faded on it and it needed new sheet metal for the hood and one rear fender. Still, for the price, I think that would have been a heck of a deal for the money. As you can tell, I'm still bothered that I waited (literally weeks) before I decided I'd add it to my fleet only to find that someone from out of state came in and was thrilled to get it. Figures.
/ Best tractor list #60
Okay Egon, no more useless posts from you just to add to your post count!
Status
1999 Freightliner FL112 Tri-Axle Dump Truck (A66736)
1999 Freightliner...
Unused 2023 Del Morino Funny 132M Hydraulic Flail Mower Attachment (A66734)
Unused 2023 Del...
HITACHI ZX270LC Engine (A68134)
HITACHI ZX270LC...
2015 Honda Accord Sedan (A66738)
2015 Honda Accord...
2014 DODGE 5500 SERVICE TRUCK (A67714)
2014 DODGE 5500...
2013 C&M TRAILER T/A 20 UTILITY TRAILER (A67714)
2013 C&M TRAILER...
