Buying Advice best tractor for mountain property-
   / best tractor for mountain property- #11
True the skid is the way to go for this yard but at $80k it would be cheaper to hire it out.
   / best tractor for mountain property- #12
I live in Nelson Co, VA as well, right in the foothills of the Blue Ridge Mountains.
I had a 4700 with R4 tires that was mostly able to negotiate the hills on my property, except for a few extreme ones.
I agree that the 4000 series are excellent in this type of terrain. My rear tires were at there most narrow setting the entire time I had it. It did get close a couple of times. Did have fluid in the tires, however.
James River Equipment does have some used 4000 models. Here's what I see under 20k ish:
4200 Hydro 4x4 $4,800
4115 w/410 loader $13,900
4230 w/400X loader $21,999
   / best tractor for mountain property- #13
Something with a roll over protection system, seat belt, power hydraulic wet enclosed brakes, live pro, live hydraulics, differential lock, M4WD, power steering. Something with a low wide chassis and low wide tires. Hydrostatic transmission would not hurt either.If somebody tries promoting the N series Fords etc to you, thank the person for trying to kill you and walk away. Travel slow on slopes. A minor bump or hollow has flipped many machines.
   / best tractor for mountain property- #14
i would get a used jd 5210 mfd.,at least a 5105.they would be so much more useful than a skid steer and would do a lot more work than a 4000 series.
   / best tractor for mountain property- #15
I have a smaller piece on mountain land than you. I love it. Whatever you get, make sure you get a backhoe on it. I use mine all the time for stumps, cutting elevations and everything in between. Invaluable tool for mountain land
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
New Holland 276 Square Baler (A50774)
New Holland 276...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2000 Ford F-650 TMA Attenuator Truck (A50323)
2000 Ford F-650...
Rears 500 Gallon Orchard Sprayer (A50120)
Rears 500 Gallon...
