Best tool to smooth sand/soil with Ranger
   / Best tool to smooth sand/soil with Ranger #1
lindaandmike
I have a Ranger 500. My grandkids love to run it on my beach. They leave huge ruts. I've tried dragging a 6ft 3" piece of angle, but it is not very good. They also have a motorcycle track in the dirt which gets big ruts and needs to be smoothed.
What would be a good tool to drag either behind the Ranger or a large ATV?
Thanks, Mike
   / Best tool to smooth sand/soil with Ranger #2
Hi Mike.
Try taking a look at this youtube video: YouTube - ATV Box Blades and Grader Blades
The companies website is: Atv Plows Plus
If you're looking to do it on a budget then a heavy piece of metal RSJ / girder should work on the sand, although you may need to scuff it up to loosen it first - maybe try dragging a chain harrow, then your piece of angle?
Hope this helps :thumbsup:
   / Best tool to smooth sand/soil with Ranger #3
I use a DR Power Grader behind my RTV 500 and it works great....they aren't cheap but they do come up used for a fair price pretty often.
   / Best tool to smooth sand/soil with Ranger #4
For smoothing sand, try dragging a reasonably large section of chain link fencing.
You will want to have a rigid pull bar that might simply be 2 flats (or one and a similar angle) bolted thru the chain link fencing.
2 equal lengths of chain from the corners to your tow bar or hitch for pulling.
If you find that you are snagging obstacles like racks or stumps you can install a small tire to act like a shock absorber near the hitch.
We used to maintain a gravel road like this and pulled with an old jeep.
thank you....looks very interesting. Mike
   / Best tool to smooth sand/soil with Ranger #7
I used to drag a pallet (top side down) loaded with rocks around here.
I'm a Cheap-skate though, if I had the money, I'd buy a tractor with a
box scraper.
   / Best tool to smooth sand/soil with Ranger #8
i would use the fence with a angle iron on both ends and drop a cender block or two on it.when clearing out the trails we drag a 8' section of chain link fence behind the rhino or other utv we are useing.it really does the job on the weeds and dirt leveling.
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A55315)
Mahindra 4550-4L...
2002 Frieghtliner Pressure Digger (A55973)
2002 Frieghtliner...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
