best tool for the job
   / best tool for the job #1
farmerjim
new london county,ct
jd h, jd 50, jd2010,jd 790,case530hoe
i need to place some drain pipe around my house and my buddy sold his back hoe b4 i got to use it. so now i need to rent a machine to do it. the local rental place has mini excavators 3 sizes from a small kubota 1.5 ton class, an 11klb class komatsu and a cat 305 which i think is way to big to be working close to my house. they also have a 6.5ft 3pt backhoe which could be used on my jd 790. i was planning to rent for a day and do the digging then place the pipe the next and back fill w/ my loader. just was wondering which machine would be best for the job. thanks jim
   / best tool for the job #2
For drain pipe around the house, you don't need a big powerful hoe. You're probably not going to be digging super deep, are you? I think the smaller hoe or even the 3pt hoe would do just fine. Being able to get into wherever you need to dig would be my first concern.
   / best tool for the job #3
3pt hoes are ok for light duty work.. homeowner burried lines or small drains.. OK.. any 'real' excavation or rock picking / clearing / demolition is a no-no for a 3pt hoe though.. as it leads to 'half-tractors'
Just take it easy and you should be find for digginf a couple feet in regular soil.. etc..
Soundguy
   / best tool for the job #4
Ditch witch. I have done hundreds of feet for irrigation and will be having a buddy bring his tracked machine with trencher that trenches 8" wide and 4 feet deep this Saturday for 500 feet+ of drainpipe.
   / best tool for the job #5
I second on the Ditch Witch, self propelled one is to easy
   / best tool for the job #6
If a Ditchwitch will go deep enough for your needs that would be the easiest way to trench. If you are in rock country that can be a problem. Next I would vote for the small excavator. They really excel when you are working close to the house.
MarkV
MOBILE OFFICE CONTAINER (A53843)
MOBILE OFFICE...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
2004 FREIGHTLINER COLUMBIA (A53843)
2004 FREIGHTLINER...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
