Best source for mower belts?
/ Best source for mower belts? #21
The belt was broken so I stretched it out and measured it.
Also when I searched for it by manuf # some of the websites gave the length.
an eBay search usually has vendors listing belt by sears # and then they also give length.
Once you know length then search by length for best deal
/ Best source for mower belts? #22
Taking a broken belt and laying it out flat is not a good way to measure it. You will get the wrong size everytime. (But some times it will still work as there will be enough play in the tensioner.)
V-belts have two length measurements. And inside diameter and outside diameter. Depending on belt width (A/4v-series; B/5v series; C/6v series; etc)....the ID and OD measurement of the belt can be 2-4" difference.
When you take a broke belt and lay it out flat.....the ID and OD become the same you only have one measurement. And that measurement you come up with is acutally somewhere in between the two.
For example.....On B-series belts of the ~60" range.....there is a 3" difference between ID and OD. LEts say your application calls for a B-60 belt, which is a 60" inside diameter belt. (Which is the same belt as a 5v630). That belt will have a 63" outside diameter. Cutting that belt in half and measuring it would give you something in the 61-62" range. So if you went and bought a B-62, your new belt would be 2" too long. IF you got a 5v620 (also a 62" belt), your belt would be 1" too short.
SO you have to know how belts are measured.
IF you are unfamiliar with belts
Tailgate Mulcher Portable Hay Blower (A65579)
Tailgate Mulcher...
2001 Club Car Carryall 6 Medical Utility Cart (A64553)
2001 Club Car...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2021 Kenworth T880 Tandem Dump Truck, VIN # 1NKZL40X6MJ464380 (A65563)
2021 Kenworth T880...
