best solution to stop fence post rust
   / best solution to stop fence post rust #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
I have some new fence posts that will need to be painted. They are oilfield pipe and have a light rust on them. What is the best way to stop the rust and paint them? There are only 9 posts, and they are on the cornere of a building (not miles of fence...) They will be painted red...
   / best solution to stop fence post rust #2
Simple Mike, eliminate moisture! If thats asking to much I like using Damp Proof Red Oxide primer. Rust Oleum makes it. It was exceptionally good in the old days but I think they had to take the asbestos, arsenic, dioxin, lead, selenium, radon and other such stuff out /forums/images/graemlins/smirk.gif. Rat, thats Mr Rat to you!
   / best solution to stop fence post rust #3
Yep the Rusatoleum rusty metal primer is good stuff. A couple coats to be sure then a good oil based topcoat, best I have found available for retail sale yet. It is tender for a while but will harden up nicely in a month or so. I have used it on the underside ow mower decks with good results. Did the underside of my Gravely deck a couple years ago and it is still there, not even beat off, and I use the gravely as a small brush hog.
1268 (A50490)
1268 (A50490)
JARRAFF TREE TRIMMER (A52706)
JARRAFF TREE...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
