Best setup for dragging logs??
   / Best setup for dragging logs?? #11
If you are wanting to saw the logs for lumber, you should use a log arch. It will minimize the contact with the soil and make your band saw blade much happier!
jb
   / Best setup for dragging logs?? #12
20060327
Log arch--that was the thread you should look for -- someone made one out of an old rolabar hay rake.
Or do a Boolean for "log" and "rake" and "arch" in the same post--might narrow it down for you.
Like the boom pole deal the other guy just showed in his pics, it lifts the front up so it is less likely to catch and jerk the tractor around. I think that's the idea--logging experts chime in 'cause I'm not one.
J
   / Best setup for dragging logs?? #13
There's a recent discussion in the Mahindra forum on this topic. There were some good suggestions made there. Check it out.
BR
   / Best setup for dragging logs?? #14
You know if you're just making firewood then why not buck them in the woods and load them on your FEL on forks or on the rear somehow. Maybe even a trailer. You've got to cut it anyway and the less you drag it the cleaner the log will be which will help the saw stay sharp.
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
2012 BROCE BROOM (A50854)
2012 BROCE BROOM...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
GENERAC GP6500 GENERATOR (A50854)
GENERAC GP6500...
Handlair 555 Grain Vac (A50514)
Handlair 555 Grain...
