Best saw for use on ladder while trimming trees
   / Best saw for use on ladder while trimming trees #11
I like my electric chainsaw for trimming , its light and It was 10 bucks at a yard sale
   / Best saw for use on ladder while trimming trees #13
:thumbsup:
Yep, me too. I don't do anything on ladders around trees. You can never be certain where a cut limb will go.
I use the Ridgid saw, from the ground, and anything I can't reach gets cut with 16' Echo Pole Saw. If a cut limb comes my way, I can step away. Can't do that on a ladder.
   / Best saw for use on ladder while trimming trees #14
You're welcome. I am a year older than you and a limb clipper is what I would get if I had a lot of them to do.
Check this thread: http://www.tractorbynet.com/forums/buying-pricing-comparisons/326582-wolff-limb-clipper.html
I wish they had something like that strong enough for big roots that you could put on a backhoe. I've actually thought of making one up myself. It would have to have big curved bypass blades like a lopper.
   / Best saw for use on ladder while trimming trees #15
This is the only way to go. I'm no nervous Nellie but to be on a ladder with a chainsaw is a bad idea. The Sawzall is OK if you stay on a low ladder. Having seen chainsaw cuts from bad decisions on ladders, the only way I would be serious about limbing is the limb clipper thing above.
   / Best saw for use on ladder while trimming trees #16
I cut trees for a living, and there is NO WAY I would risk doing the ladder/saw combo.
Better to get a Silky polesaw and get good with it, sure it will be exercise and patience but less that having to learn to walk again when the ladder spits you off, cradle and all.
   / Best saw for use on ladder while trimming trees #17
Is that YOU up in that tree?
Thanks Timbersawz; I have checked out,on line, the Sisky pole saw. they are pricey. Are they really any different or better than other manual pole saws??
Have a great Day,
Red Cox
   / Best saw for use on ladder while trimming trees #19
The silkys have fantastic blades, cut better than anything else I have tried. They do take a bit of time to get the hang of using. The most important things are to
1) not try to cut to much at once, best take the branch in a few cuts if its thicker than 30mm.
2) make sure you have a clear zone for the blade to work back and forth (no little twigs to get pulled and jammed into the cut)
3)make nice straight gentle pulls of the saw.
They do take some time to master but have fantastic reach. start on little branches, work to avoid jams or having the pole get swung into, as its a long way up for it to get stuck!
That isnt me in the pic as I take the pics, but that tree is being used as a spar pole to cable out other logs in the gully, I took the top out of it and the others around it the day before. I have literally thousands of pics of us doing tree work but very very very few have me in it.
This is me, taken by a pro photographer no less some years back.
   / Best saw for use on ladder while trimming trees #20
The silkys have fantastic blades, cut better than anything else I have tried. They do take a bit of time to get the hang of using. The most important things are to 1) not try to cut to much at once, best take the branch in a few cuts if its thicker than 30mm. 2) make sure you have a clear zone for the blade to work back and forth (no little twigs to get pulled and jammed into the cut) 3)make nice straight gentle pulls of the saw. They do take some time to master but have fantastic reach. start on little branches, work to avoid jams or having the pole get swung into, as its a long way up for it to get stuck! That isnt me in the pic as I take the pics, but that tree is being used as a spar pole to cable out other logs in the gully, I took the top out of it and the others around it the day before. I have literally thousands of pics of us doing tree work but very very very few have me in it. This is me, taken by a pro photographer no less some years back.
Man, you gotta use that pic in a commercial or something - great action shot!👍
Butterfly Artwork (A55758)
Butterfly Artwork...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
Hercules Pesticide Applicator Tank with Nozzle (A55852)
Hercules Pesticide...
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2007 Saturn Sky Convertible Coupe (A54815)
2007 Saturn Sky...
