Tiller best rotary tiller out there -hlep!
   / best rotary tiller out there -hlep! #1
hotchkiss
Ohio
JD 6330, JD 5055e, Ford 4000,
I just purchased a new New Holland TN95A with approximately 77 hp at the PTO. I have nearly new 6 foot King Kutter heavy duty tiller, but am looking for the best heavy duty rotary tiller that is out there which is rated for 70 to 80 PTO horse power. What are your suggestions? Thanks.
   / best rotary tiller out there -hlep! #3
Kuhn builds good tillers as well as Howard. It depends on your use in soil as well as the amount you have to do.
   / best rotary tiller out there -hlep! #4
Land Pride RTA35 Series Rotary Tillers
With a 19" rotor swing diameter, this tiller can turn over a bunch of dirt, without much getting in the way. The Cat. 4 slip-clutch driveline and 75 HP gearbox keeps the power coming in the tough conditions. The spring loaded rear deflector keeps the tailgate on the ground to level and keeps larger debris in for more pulverizing action.
   / best rotary tiller out there -hlep! #5
hopefully this is right as this is my first message.I've had 4 landpride rtr 2570's excellent machine tills sod to nothing in 2 passes.Chain is wink link as i've busted a few and had them come through side case.put new chain on welded case back on the road.i bought maschio b 180 last year a beast.no problems last year only went through 1 set of tines on land prides i would have went through 2.also has 100 horse gearbox.Jerry
   / best rotary tiller out there -hlep! #6
I'm also looking and was wondering if the Woods SGT line lives up to it's price?
   / best rotary tiller out there -hlep! #7
bush hog makes a good one they have three different lines, light to heavy duty
Lets keep this discussion going. So far, I have concluded that the Frontier and John Deere tillers are over rated and over priced. I think the Kuhn's look pretty good, but they are expensive. Has anyone used the CCM Super Heavy Duty tiller that is approximately 90 inches wide. The price seems reasonable. Thanks for you help and opinions.
   / best rotary tiller out there -hlep! #9
Yes..let's keep this going. Any info on Woods out there? CCM users chime in!
   / best rotary tiller out there -hlep! #10
Kuhn. Hands down. They build tillers that take way more hp than that. Look at the options they offer. Anyone else build a model heavy enough to power an another implement behind? It's an example of getting what you pay for.
set of 4 wheels and tires 205/75R15 (A56435)
set of 4 wheels...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2021 Boss 990 Fuel Trailer, VIN: 1F9BT1028MB503652, Honda GC 160 Gas Fuel Pump, Tandem Axle, GVWR: (A59076)
2021 Boss 990 Fuel...
2020 Freightliner Derrick Digger Truck (A55973)
2020 Freightliner...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
