Best Product to Oil A Snowblower Chain??
   / Best Product to Oil A Snowblower Chain?? #1
NY_Yankees_Fan
Warren County, NJ (60 miles from NYC)
Kubota BX 2200
I have a 3 pt, 54 inch Puma snowblower, reading the manual it says to lubricate the chain every 8 hours. I sprayed on white litho grease on the chain. Just wondering if this is the best product or is good old 10-40W just as good? What product should I use??
Thanks
Tom
   / Best Product to Oil A Snowblower Chain?? #2
I would get a can of Motorcycle chain lube.... when you spray it on its liquid, it gets between and in the chain, then turns thick after 10 secs, good stuff.
   / Best Product to Oil A Snowblower Chain?? #3
As your manual states, chainsaw oil is the best. Chainsaw oil is designed with special additives that stick to metallic surfaces, thus assuring better lubrication properties.
I have personally experienced that chainsaw chains will last longer using chainsaw lubricant rather that motor oil. Hope this helps!!!
   / Best Product to Oil A Snowblower Chain?? #4
I like to use chain lube on all my link chains. It just sprays on and stays put really well. I buy mine at my Massey dealer. One more thing, it works really well on the seat rollers. It makes the rollers quite and the seat go up and down real smooth.
   / Best Product to Oil A Snowblower Chain?? #5
I'd say it wouldn't matter a whole heck of a lot what kind of oil you used. Just as long as it's thick enough to stay. Chainsaw oil would be good although the chain you'd be oiling isn't taking the abuse chainsaw chains take but the oil is cheap enough. If it were me, I'd use motorcycle chain lube. After all, it is made for that perticular purpose. The most important thing is to oil the chain. Just don't use WD-40.
Billy
2013 Nissan Sentra Sedan (A53424)
2013 Nissan Sentra...
40ft Sea Container (A52384)
40ft Sea Container...
Bush Hog 9670 8FT Pull Type No Till Grain Drill (A55218)
Bush Hog 9670 8FT...
TEST YOUR BID BUTTON! (A54756)
TEST YOUR BID...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A55218)
2023 NEW HOLLAND...
