Best Position for add-on lights
   / Best Position for add-on lights #1
ctgoldwing
Platinum Member
Central Connecticut
L3800HST
So now that I am no longer 'tractorless' I want to add some lighting. Its something I never did with the L3400 that I sold last year and pretty much regretted it every time I had to work with it at night. Now I have an L3800. Where have operators had the best results mounting LED lighting?
I surely would like to put rear lights in and while at it additional front lights wouldn't hurt. I do work in the woods with it so branches can be an issue.
TIA
   / Best Position for add-on lights #3
0D91AA2B-6B22-4623-89DB-76E959BF1ABF.jpegUp high on the ROPS is best. If you have the fold down type, that may or may not work. My main need for lights is snow removal. I don’t really like to put my ROPS up unless I have to and for snow removal I don’t have to. Mine are just about head level on the left upright on my ROPS. It’s fine most of the time but the forward facing on can blind you a little when looking over your shoulder and can also reflect off my glasses sometimes. You can kind of see them in the pic.
Very clever mounting them in the tube for side lighting. I can certainly do that :)
I do have a loader perhaps I can find a high and or low spot(s) on the brush bar to mount forward facing lights.
Thanks!
View attachment 667543Up high on the ROPS is best. If you have the fold down type, that may or may not work. My main need for lights is snow removal. I don’t really like to put my ROPS up unless I have to and for snow removal I don’t have to. Mine are just about head level on the left upright on my ROPS. It’s fine most of the time but the forward facing on can blind you a little when looking over your shoulder and can also reflect off my glasses sometimes. You can kind of see them in the pic.
Yes if I kept the ROPS up all the time that would be an easy solution. I can't get it in the garage with it up tho. Maybe mounted on the side of ROPS. . . hmmm that should work as long as I'm careful in the woods.
Thanks
   / Best Position for add-on lights #6
I'm probably different than most people. I like my lights below eye level as any dips/contours etc show up so much better. If the lights are above eye level they are all washed out because there are no shadows to differentiate anything.
   / Best Position for add-on lights #7
I mounted mine using steel pieces that kind of look like erector set pieces. Flat steel with holes in it. I’ve brushed up against some trees and bent them a couple of times but they bend back. I’ve hit my garage twice with my ROPS up so I don’t put it up unless I’m working on hills. I started blocking my garage with 5 gallon buckets so I do not forget when it is up. You will notice I have the rear one pointed down quite a bit to light the rear blade when plowing.
   / Best Position for add-on lights #8
Like you I am in the woods often so I mounted them on the inner side of the ROPS. I used one bracket on each side to hold both the front & rear lights. I wasn't sold on the location at first but we have been very happy with them; glad we put them up high. With them mounted inside the ROPS we have zero issues with trees or branches.
We setup separate switches for the front & rear
   / Best Position for add-on lights #9
That's my experience.
   / Best Position for add-on lights #10
If I could not or don't want to add lights to ROPS, I think I would put them on a pedestal on support for FEL pivots...
I moved my tail lights - turn signal lights to "inside" my ROPS because I learned the replacements are $125 each......
Dale
2012 Ford E-250 Cargo Van (A55852)
2012 Ford E-250...
2011 Kia Forte Sedan (A55853)
2011 Kia Forte...
2024 Timpte 40ft Hopper (A55315)
2024 Timpte 40ft...
2019 Ford F-350 XL (A53317)
2019 Ford F-350 XL...
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
2004 Towable Light Tower (A55851)
2004 Towable Light...
