Best place to purchase pto shaft
   / Best place to purchase pto shaft #1
screamin400
Platinum Member
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
I need a shaft splined on each end about 40 inches long closed that will handle 35 hp. Where should I look for one?
   / Best place to purchase pto shaft #2
I used Agri-Supply because my rotary cutter had different splines on each end, they helped me get the correct shaft. Agrisupply.com
   / Best place to purchase pto shaft #4
Years ago, I needed a new shaft for my PTO auger... or a new U joint, which was proving hard to find quickly, and I wound up ordering a new shaft from the auger manufacturer- I was surprised and happy with the price (Italian made shaft). Plus, it was precisely what I needed. Might be worth checking?
   / Best place to purchase pto shaft #5
Depends on how fast you need it,,
I got a brand new one off eBay for $100 delivered,,, it was a perfect replacement.
Thanks guys. I do keep an eye on ebay. I need one for my snowblower so no rush. Actually been looking at used implements that may have the shaft I need. Might be better off to put that money toward a new implement if the shaft can interchange. Have not found one though is the problem.
   / Best place to purchase pto shaft #7
I'm cheap and just borrow one off another implement.
   / Best place to purchase pto shaft #8
I know Agi-Supply has them splined on both ends at a reasonable price. Was looking at some a couple of weeks ago. Does the implement have some sort of shear or clutch beyond the shaft to protect the tractor if it locks up?
   / Best place to purchase pto shaft #9
Rural king can be reasonable if you have one near. Agri-Supply will be cheapest.
Blower uses shear pins. I am wondering if I should look into one with a slip clutch just in case I ever want to take it to another machine? What could it hurt?
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50775)
ALL ITEMS NOT...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
New Wolverine Skid Steer Root Rake Bucket Attachment 34'' (A53002)
New Wolverine Skid...
