Best option for a Grapple?
   / Best option for a Grapple? #1
trlbrkr
New England
02 NH Tn 75D-06 Kubota 105X-14 Toolcat 5600G-13 Kubota Excavator U35
   / Best option for a Grapple? #2
I presume the toolcats have a universal (Bobcat) skid steer mount. If so, why not use a light duty grapple. My 48" Millonzi weighs only 280lbs and though labelled "light duty", it is made of 3/8 inch steel and should be very capable of handling anything you would reasonably do with a toolcat. Cost is much less than for the heavier grapples too. I don't know what they are quoting for them now but you can PM Joe Millonzi here on TBN (joe@millonzi) to get a special TBN quote. I believe Piranha also sells a similar sized unit.
You really don't need more than a 48" grapple if you are handling brush so don't think you need a grapple the same width as your bucket.
   / Best option for a Grapple? #3
Island Tractor,
Did those decals come with your grapple?
Also, what size tractor do you use with the grapple?
-Mike-
   / Best option for a Grapple? #4
trlbrkr said:
I am in the process of buying a D and was disappointed the root grapple is 600pds and too heavy for the toolcat . I would be using it for brush and cleaning out the haypack in barns. At this point I am considering a 62" bucket mounted with 55"grapple? I also found this online but Westendorf did not list weight . Front-End Loaders by Westendorf: loader for tractor, shade canopy, wagons, manure & landscaping equipment.
The work you describe is what I do with the Bobcat utility grapple. If you have a need to go into the ground after roots I don't think it would hold up.
I clear trees out of fence lines, push them together, pinch em with the grapple, go to a ditch and dump. I can carry far more with one grapple load than I could by dragging them onto my 6x12 trailer due to being able to pinch them. I load manure that has hay mixed in that the bucket will not pick up. I also load round hay bales onto a trailer with it.
I can't find any good pictures of it on the new Bobcat website. The model I have uses replacable tines which allows you to add/remove tines to customize the attachment for your application.
dsb
   / Best option for a Grapple? #5
Do you work for the Adam's Family? Spooky looking house.
   / Best option for a Grapple? #6
Traditional 120yo Victorian "beach cottage". No ghosts
   / Best option for a Grapple? #7
mscheer772 said:
Island Tractor,
-Mike-
Not sure what decals you are referring to. The "safety" decals all came on the grapple.
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54313)
2019 KENWORTH T680...
2015 DOOSAN P185 PORTABLE AIR COMPRESSOR (A51406)
2015 DOOSAN P185...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
4 Unused Montreal ST205/75R15 Trailer Tires (A53421)
4 Unused Montreal...
Volvo EC330 BLC Excavator (A54865)
Volvo EC330 BLC...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
