Best Oil Weight?
/ Best Oil Weight? #1
npaden
Platinum Member
Lubbock, Texas
2011 LS U5030C
Okay, I don't want to start a war on oil brands or anything and have searched trying to find the answer, but on the Kubota website it has this blurb for recommended engine oil for my L4200:
<font color="red"> "Engine Oil (Below 32°F use SAE10W or SAE10W-30 or 10W-40) (32°F to 77°F use SAE20 or 10W-30 OR 10W-40) (77°F and above use SAE30 or 10W-30 OR 10W-40)" </font>
Based on that it looks like I could use 10-30 or 10-40 for all conditions.
My natural instinct would be to use 10-40 in the summer and 10-30 in the winter or just use 10-40 year round.
What do you guys think?
Thanks, Nathan
/ Best Oil Weight? #3
Hi Nathan:
I always have ran full synthetic, Mobil1 Delvac. Recently Mobil has repackaged Mobil1 Delvac as ‘Truck and SUV’ you can find it at Walmart in 5 quart containers and a good price.
But like sneaky pete said “In Lubbock you will be fine with 10W-40 all year 'round.” KennyV.
/ Best Oil Weight? #4
the mobil 1 truck and suv or delvac or rotella t
is all 5w- 40. It is a highly respected oil for light to heavy duty diesel engines. I run it exclusivly in my vw tdi.
vw says i can go 10,000 miles between oil changes with this stuff.
I just can't bring myself to even try this once so i do them every 5k.
The oil designed for diesels is ci and ch4 rated for high
compression "shearing" as they call it. regular dino 10w40
is not designed to run in diesels.It will break down quickly.
just my 2 cents
Guess i should have asked...Is your bota a diesel?
/ Best Oil Weight? #5
Can't find any 10W30 or 10W40 diesel-rated engine oil around here. Everybody (TSC, WallyWorld, NAPA, etc) sells 15W40. So I use Rotella 15W40 in my B7510HST. I checked the TBN forums and that Rotella oil is apparently OK.
/ Best Oil Weight? #6
I switched to Mobil1 Synthetic 10W-30 at 50 hours. I run everything on it.
/ Best Oil Weight? #7
OB1…
Yes you are right… I also don’t go extreme miles or hours. I change engine oil in my Kubota (diesel) L4200 once a year… Wix filter and mobil1 Delvac/suv /forums/images/graemlins/laugh.gif… KennyV.
/ Best Oil Weight? #8
npaden -
My 2 cents worth - as others have said, conventional 10W-30 in a diesel formulation doesn't seem to exist (I guess Kubota doesn't realize this?). To me, 15W-40 seems a little thick for winter use, and 5W-anything just seems a little thin for the summer. I went with (Amsoil) synthetic 10W-30 for year-round use, and I'm not lookin' back. /forums/images/graemlins/smile.gif
There are plenty of other good synthetics out there; I just went with Amsoil because I think it's darn good and my local NAPA carries it. Some say Royal Purple and Redline are even better, but I doubt it's by much, and they're even more $$$.
As I've said many times before, I think the most compelling reason to use synthetics is for their superior cold-weather characteristics, and extra measure of protection in the event of a cooling failure.
There have been quite a few threads lately where the subject of synthetics has come up, and it's been very civil, which is nice. I think a consensus has been arrived at that synthetics are better than conventional oils at just about everything, but that the added cost might or might not be worth it to any particular person. Hope that sounds reasonable.
Good luck with whatever route you go,
John
/ Best Oil Weight? #9
If you use your tractor every day cost is indeed a factor.
Mine gets changed once a year so no problems spending the money for synthetic..
/ Best Oil Weight? #10
</font><font color="blue" class="small">( npaden -
)</font>
Well..the 10W-30 oild..DIESEL RATED.."does exist"...but NO ONE CARRYS IT?? Most wont even bother to special order it in??? And after buying one single qt of Kubota 10W-30..at $3.10 a qt... /forums/images/graemlins/mad.gif...I went on the hunt myself.
Only thing I found that was "readily available"...which to me is very important...was Rotella 5W-40 SYN oil...at $18.95 a gallon. Im SURE its a better oil that whatever Kubota is selling..and I'll do my oil changes at the prescribed times..regardless..Syn oil or not.
It was the "principal" of the whole thing that got me.
/ Best Oil Weight? #11
15W-40W of whatever brand you want will work just fine in Lubbock year round.
/ Best Oil Weight? #12
I am getting ready for my 50 hour service on my BX 2230. I was planning on getting Mobil 1 Truck and SUV, but I just wanted to check on something first...the container says (about 3 different places) that it is for "hard working gasoline engines", and never mentions diesels. This stuff is good for diesels too, right??
/ Best Oil Weight? #13
YES, YOU DO NEED A OIL FOR DIESEL ONLY. THERE IS A DIFFERENCE. THE DIFFERENCE IS IN THE LETTERS LIKE CF,CF-2 MAYBE SOMEONE ELSE CAN HELP YOU MORE.DONT USE OIL FOR A GAS ENGINE.CALL YOUR DEALER. RICH /forums/images/graemlins/smile.gif
/ Best Oil Weight? #14
Mobil 1 Truck and SUV is the exact same oil as Mobil Delvac 1. Mobil Delvac 1 is heavy-duty diesel oil. The name Mobil 1 Truck and SUV is getting ready to change to Mobil 1 Heavy Duty Truck in the near future. The best that I can remember that is what the new name is going to be.
/ Best Oil Weight? #15
I guess I am lucky. I can buy 10w-30 CI-4 oil at a farm store nearby for something like $1.69 per quart. It is a brand called "Champion"(?). I change it once a year whether it needs it or not. If they ever quit carrying it, I will just use 15w-40.
/ Best Oil Weight? #16
I use Mobil1 10W-30 which meets "Requirements for Diesel Powered Vehicles where an API CF or API CD is Recommended " There is extensive product data at the website. /forums/images/graemlins/grin.gif Mobil1
It is advisable that a low sulpher fuel be used with CF-4 rated oil such as the Mobil 1 Turbo Diesel Truck oil (although stated to meet CF, where Mobil1 10W-30 is only rated CF and CD and a high sulfer off-road fuel as well as low sulpher low emission fuel is acceptable.
/ Best Oil Weight? #17
</font><font color="blue" class="small">( I use Mobil1 10W-30 which meets "Requirements for Diesel Powered Vehicles where an API CF or API CD is Recommended " There is extensive product data at the website. /forums/images/graemlins/grin.gif Mobil1
It is advisable that a low sulpher fuel be used with CF-4 rated oil such as the Mobil 1 Turbo Diesel Truck oil (although stated to meet CF, where Mobil1 10W-30 is only rated CF and CD and a high sulfur off-road fuel as well as low sulpher low emission fuel is acceptable. )</font>
How do you know if your diesel fuel is low sulfur???
/ Best Oil Weight?
All "over the road" diesel that you would buy at a gas station or truck stop is required to be low sulphur.
In the past "off road" or "red dye" diesel was high sulphur but pretty much nearly all of it is low sulphur now. Not sure if you can even buy the high sulphur stuff most places even if you wanted it.
FWIW, Nathan
/ Best Oil Weight? #19
Diesel at the pump for on-road use will be low sulfer as it must meet current EPA emission controls. Dyed diesel for off road use will still be low sulpher in California (CARB) yet may be higher elswhere and isn't subject to the same taxes.
This is from the Chevron website:
"In October 1993, separate regulations from EPA and CARB took effect. The EPA set a maximum sulfur content of 0.05% mass for on-road diesel fuel, nationwide. CARB applied this same limit to both off-road and on-road (vehicular) diesel fuel. In the other states, the limit on the sulfur content of off-road fuel is the ASTM D 975 limit of 0.5% mass for high sulfur No. 2-D diesel fuel. "
If unsure, check with the station you are fueling from.
UNUSED IREV HIGH END TWO-WHEELED ELECTRIC VEHICLE (A64281)
UNUSED IREV HIGH...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
(1) 4' X 5' DIAMOND PLATE METAL SHEET (A64280)
(1) 4' X 5'...
2004 John Deere 4720 (A60462)
2004 John Deere...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
