Best Oil for older John Deere
   / Best Oil for older John Deere #1
Magruder
Michigan
John Deere 790
I have an AR that I need to change oil on for the first time. What is the best oil for an older tractor like this?
   / Best Oil for older John Deere #2
Do you have a picture of that AR??
murph
   / Best Oil for older John Deere #3
When it comes to antique iron.. keep in mind that -any- oil you can buy right now.. will be superior to what that thing probably ran on new.. and that includes brigs and stratton 30w non-det, and 'jiffy-store' 84 cents a quart type stuff.
On my B I changed the oil about 3 times the first week I had it to get it completely flushed out. i used supertech oil from wallmart.
Soundguy
   / Best Oil for older John Deere #5
I dont know if this applies to you, but in my old '52 dodge M43 I use a non-detergent oil.
anything that is real old you "may" want to keep using a non-detergent. If you do not there is a possibility that the newer detergent type oils will loosen up some sludge that may become a problem.
just something to think about.
   / Best Oil for older John Deere #6
While that's true.. that a swap from ND to D oil may cause sludge movement, you can take steps to 'help' the process along. Like go with a 50/50 mix of d/nd oil for an oil change.. use a lower hour interval.. use an intermediate filter change. or even do successive oil changes say 10 hours apart.. or a couple weeks apart.. with a filter change inbetween.
Soundguy
1827 (A51248)
1827 (A51248)
2025 IR IRE20 Mini Excavator (A52377)
2025 IR IRE20 Mini...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55218)
2015 RAM 5500...
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 68in Dual...
New Holland TS 75 Front Loader Utility Tractor (A53421)
New Holland TS 75...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
