Best Mod/add on to compact tractor or attachment
   / Best Mod/add on to compact tractor or attachment #11
BEST MOD I EVER DID, WAS GROOVE MY TIRES!
Seriously, the traction more than Doubled, I rarely use 4x4 anymore. Its amazing! :thumbsup:
I suggest this to anyone looking for more traction from a R4.
REARS
FRONTS
So how did you do that? Looks kinda like vehical siping for tractors.
   / Best Mod/add on to compact tractor or attachment #12
What Deadman did is really cool! Check out his thread on how he did it; fascinating reading, with lots of pics.:thumbsup:
   / Best Mod/add on to compact tractor or attachment #14
Bought a $100 tire grooving tool, and just manually cut them. Its like a hot knife. I cut them all free-hand and they turned out almost perfect in my opinion.
Super simple to do, but takes a little grunt work to push the tool thru. Took about 20 minutes per tire, but I spent a hour before marking them, so they ended up looking uniform.
   / Best Mod/add on to compact tractor or attachment #15
Best addition have been TnT, and loader.
My first tractor did not have a loader when I got it. The loader really made the "tractor".
Later I added TnT. Wonderful addition!
   / Best Mod/add on to compact tractor or attachment #16
Pat's Easy Change. What a time and back saver!
   / Best Mod/add on to compact tractor or attachment #17
Not the most complicated mod but probably the best one is adding lights to the top the ROPS. Headlights don't do a thing with a loader on the front. Night and day difference;)
   / Best Mod/add on to compact tractor or attachment #18
If you do much land clearing and work with wood/brush, a bucket grapple makes a big difference in how much you load in the bucket and saves a lot of off/on trips to load the bucket with a decent load by hand... Bucket forks in conjunction with this are even better. If I do any hand work i leave a pile. The grapple allows me almost always roll up and pick the entire pile...
Next to that a drawbar plate with welded on hooks to allow me to quickly attach a chain to the drawbar.
Like the tire sipping, I will have to look into that, as a little more traction would always be welcome:)
   / Best Mod/add on to compact tractor or attachment #19
Like the tire sipping, I will have to look into that, as a little more traction would always be welcome:)[/QUOTE]
In SNOW, the tires have Double the traction. I'm not sure how much better they will be in summer, but I'm sure alot! :thumbsup:
   / Best Mod/add on to compact tractor or attachment #20
Pretty simple for me...the ballast box and the tooth bar
2015 CASE CX300C EXCAVATOR (A52707)
2015 CASE CX300C...
(28) 4' FLOURESENT LIGHT CEILING FIXTURES (A54757)
(28) 4' FLOURESENT...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
2022 Chevrolet Silverado LTD (A56858)
2022 Chevrolet...
DYNAPAC CC950 SMOOTH DBL DRUM ROLLER (A52707)
DYNAPAC CC950...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
