Best material and practices for 2000' driveway
   / Best material and practices for 2000' driveway #1
sidewinder770
Baldwin, MI
NH TC35D
Hi everyone. I've found this site to be extremely valuable with all my tractor questions but this one is a little different. I know it's not really a tractor thread but since I will be using my tractor I figure it's appropriate. Not to mention all the pros on this site who do or have done what I'm looking to do.
To start I live in MI and have very sandy soil here- no clay or rocks to speask of. We built a new house and now that all the construction trucks are gone I'm trying to figure out the best materal and plan of attack for our driveway. Asphault would be nice but a bit out of my price range for this project. What I'm looking to do is put about 5000 SF of material between our house, barn and detached garage as well as about 2000-2200' of driveway probably 9-10' wide. The driveway has 1 rolling hill and a few very gradual inclines with a lot of twists and turns to it. It was 100% forest before we started so we took out all the trees where the driveway was going to be and all those within say 10-15' of the driveway edges. Being that this was forest before we started we had a lot of undergrowth and vegitation to "strip" out where the driveway was going to be and because of that and the weight of all the trucks our driveway is lower than the land off to each side. Right now it's basically 100% sand driveway which needless to say gets rutted up and washed out a lot.
Knowing that I have to build the driveway up (about 6 inches) and provide a good base material as well as a crown what material would you suggest? I've been to our road commission and they suggest a modified road base (22A) or a crushed concrete type product. I like the idea of a crushed concrete driveway because the road base seems to get pretty "sloppy" and muddy when it rains and "oozes" a lot when the frost comes out of the ground in the spring. After everything with the house we don't have much in the budget for a driveway but we need to do something.
So how would you tackle the project?
What materials would you suggest?
What method of installing the materials?
Anything else I should consider?
Right now I have a 35hp New Holland 4x4 tractor with a 6' 600lb box blade- will this be able to get the job done? I'm probably adding a HTL and a few hundred lbs of steel to the box in the next week or so.
As always thanks for any input and ideas!
   / Best material and practices for 2000' driveway #2
Answered this one yesterday.
Ah road work so fun, I just rebuilt an old logging entrance road on my property. Here are the steps and costs:
1.) Grade current road flat, bulldozer or tractor work
2.) put down 8 oz Geotextile fabric over grade, about $350 for 14x300 foot roll. keeps the rocks from sinking in the mud
3.) Put down # 4 rock with a spreader truck 16 tons for $400 each load. On 1200' I put down 7 loads. I went heavy on the #4 as I have logging trucks and large equipment moving up and down the road consistantly.
4.) After 6 months add crusher run over the #4 stone, $380 each load with a spreader truck. The crusher run fills in the holes.
The number 4 stone is pretty serious and makes for a rougher but tough driveway. Some people use 57 stone instead of #4 then put crusher run over after 6 months again. With the fact that you do not have a base started you are going to need a good 6 inches of #4 stone as your first layer.
Steve
   / Best material and practices for 2000' driveway #3
I just did over 9,000 sq ft of horse trailer turn-a-round and driveways to home, garage, barn and horse paddock. Here were the steps I took:
- hired experienced dozer/operator
- add base fill as needed to correctly grade base for drainage
- add geo textile material to cover base
- add 8 inches of 3/4 down limestone
- had dozer perform finish grade and compact
Absolutely amazing what a skilled tracked dozer operator with laser levels can do in a short amount of time. Definitely the right tool for the job gets the job done right.
swiss- Thanks for the input, I did see your post on that thread as well. Little different situation for me since I have a driveway lower than the sides and just sand instead of a shale base. I've never used or heard anyone around here talk about using geotextile fabric. It makes sense to me but people around here aren't to up on modern practices either.
dmay- I've thought the same thing about getting someone with a dozer to get me a better rough grade and fill in some low spots. Not sure if we have a good supplier here for crushed limestone but I can make some calls.
I'll have to see what I can find for geo fabric suppliers around here. Sounds like I'd need about 6+ rolls of that stuff!
Sounds like I could use #4 rock as a base and to build up a bit as well- just depends on cost really. Is there something that would work just as well as the #4 for both base and finish?
   / Best material and practices for 2000' driveway #5
Sidewinder770: You mentioned sides higher than road and in all the excellent advice you received no mention of swayles, culverts or rip-rap. You also say the drive has turns and small inclines.
Here in Colorado I bought 40 acres W/a 1/3 mile driveway, leading to a circle drive completely around the house and barn. Under that drive run four culverts that channel the swayle run-off into a pond.
Here is what I did, take what you like: The swayles should be present, but not deep ditches and the entrance and exit of each culvert should be rock lined, that's the rip-rap. If no rip rap the culverts will clog with mud in heavy rains. Place a few rip-rap rocks every 50 feet or so in the swayles to allow the water to pass but hold back the earth. The swayles should also have grass growing in them, no weed killer. Roots hold soil, bare soil washes away.
The previous owner of my place had culverts installed W/no rip rap, all were hopelessly clogged with mud and useless. I replaced them all, cost some $$ but now my property drains beautifully.
YES! Hire a top notch excavator, not your neighbor W/his BobCat. Get references and go look at his last three jobs. If he won't let you, he's not for you. Look into recycled asphalt as a driving surface. I have four inches of that over 6 inches of CDOT road-base. In the winter its hard and plows easily. In summer, being asphalt it gets warm and "melts" a bit into as close to a paved surface as you can have, short of a paved surface. It is nearly dustless, drains well, and I can easily grade it with my BobCat utility vehicle bucket. I have almost all clay here (horrible crud) in a troublesome low spot my excavator used crushed 3/4 cement, basically old freeways. It locks together and will not walk or sink in. Then the recycled asphalt over that. One more benefit from the swayles, they give you a place to daylight the rain gutters keeping that water away from the house. Good Luck.
Rottresq- Thanks for the info. I think you have a very good point about the drainage. The only difference here is water doesn't puddle at all (except in low spots of the driveway because it's compacated and frozen right now). Once the water gets off the driveway it soaks in faster than you can imagine. I think the key is to get the driveway higher than the land next to it and have a good crown on the driveway. Once the water gets off the driveway it will soak in really fast. Seems they did a good job getting rid of most of the topsoil and down to just bare sand which is good- I just need to build it back up with something that will drain well.
I'm making a few calls to some local excavating and gravel companies to see what they advise and get some quotes going. I kind of thought this could be something I could do myself but it's sounding more and more like it would probably be better to get a pro in to do it.
I'm thinking about reclaimed asphalt or reclaimed concrete as a top coat but we'll see what kind of pricing I can get on that. So I'm thinking I'll build up a few low spots with sand (or maybe road base), then use the fabric with a good 4" base of #4 to get it above the surrounding area. Do I need to wait to put the top coat of reclaimed ashpalt/concrete down or can that be done right after the base is installed?
As much as I don't have a lot of money to throw into this it sounds like something that should be done right the first time because fixing it later will just cost more time and money.
Thanks all for the advise and keep it coming as I need all the options and opinions I can get!
   / Best material and practices for 2000' driveway #7
You should compact all the layers. This is where a tractor just is not a good fit. A dozer is soo much heavier, has tracks and a big wide and heavy blade.
So get your base down, graded and compacted. Then add your geotextile material. It is nothing special. Similar to garden landscape cloth just heavier fabric and larger roll. You simply unroll it and add your top layer over top.
The purpose of the geotextile is to separate your expensive top material from base fill. Otherwise after time they will mix and eventually your top material can be absorbed into the base, requiring more top material and more work and never ending $$$.
   / Best material and practices for 2000' driveway #9
I vote at least one of you post pics. All those in favor - say I.
Ok. The I's have it. :D Please post pics. :thumbsup:
   / Best material and practices for 2000' driveway #10
Why don't you check out if there is any road re-surfacing coming up in your area and get them to dump the millings on your property,I did the this and the road crew were more than glad as it save them on haualage to dump site, the millings make fantastic driveway.
   / Best material and practices for 2000' driveway #11
I would recomend that you go wider, maybe at least 12' with your driveway, which is more like a single lane on the co. road. With curves, if you have any delivery trucks, propane etc they might be cutting the corner. There are some good pics of someones sheetrock truck nosed into the soft stuff on here somewhere. Also maybe a turn around/passing spot in the middle somewhere for when you head to town and oops I forgot something.:ashamed:
   / Best material and practices for 2000' driveway #12
Absolutely agree with this. The wider the better. Especially if your driveway is close to any buildings, fences etc it needs to be wide enough for you to clear extended trailer mirrors and if parked open your vehicle and trailer side doors. Also consider your trailering needs. Can you easily enter/exit/turn when pulling a trailer. Your entry/exit point might be better to widen out to 24 ft to provide adequate room to swing a truck and trailer entering and leaving your driveway.
I trailer horses so I went 24 ft wide the entire driveway. Also gives room for two vehicles to pass each other easily.
   / Best material and practices for 2000' driveway #13
yup,drag your boxblade back and forth till your base is smooth ,geotextile,millings.whoever said a bulldozer will pack better is wrong the tracks spread the wieght out so a bulldozer can even walk on snow.
   / Best material and practices for 2000' driveway #14
i am a tad edgy about ya not putting in any sort of ditches / culverts in. sounds like problems down the line. were you end up having ruts and muddy spots along the driveway. i been on my mom for some time about ditches. and she like oh so what if some ruts get put in. but once she started understanding things. and then better drainage in a couple spots i fixed. the ditches started looking better and better to her. she was in a mind frame. if the road is icy i will more than likely slip into them and be stuck. what she didn't understand was the need to get the water off the road and then allowing the water to run away and not stand in spots and soak in. soaked in water was causing the problems of a mushy driveway/lanes and more ruts. that resulted in gravel disappearing into the mud.
i no longer have the website on hand. but it gave details about grade percentages and widths of the driveway / road. for going up and down hills along with bends and corners. to deal with various trucks that might ever come back into your house so they don't bottom out. or cut across the drive as they turn. along with ditches and getting water off and away from the road and its base. (from crowns to sloping entire driveway width to a side)
my experience in the old dirt lanes on the farm. once ya get them graded. and then get your rock on them. try to avoid driving on them as much as you can in wet conditions. and then drive tractors with say front loader bucket full of dirt. and say a box blade and extra weight on the rear of the tractor. and drive over the road multi times when the road is dry. i say multi paths do to having to deal with the widths of the tractor tires and overlapping the tire paths each time. i tend to find it better if i drive slow. ya it takes longer. but i get better compaction due to rocks are not sliding into a completely different location.
once things get nice and compacted. then if ya drive over the base when muddy you can some without to much problems with some expected putting in some more road base to fix some spots before final rock is put on.
Well, I got 2 out of 3 quotes back so far and doesn't look good. $14,400 and $15,200. Thats for ~375 tons (mostly 6") of fill dirt and ~275 tons (about 4") of crushed concrete as well as some top soil for another project but that was only $1000 of it. That's for about 5000 SF of parking/front yard work and 1650' of 12' driveway. Both contractors so far said they wouldn't see a need for the geo fabric but I'm still not convinced of that.
I really don't have that kind of money to through at this project right now so I'll have to come up with a different plan of some sort. I really only have about 6k to spend on this right now. Maybe I could do part of it this year and some of it next year or the year after. I really want it done right but just don't have that kind of cash to spend on it right now. I'm thinking it's going to be a lot more "hands on" and doing most of the labor myself and cutting back some on the material.
Just not sure what the best route is at this point.........
   / Best material and practices for 2000' driveway #16
There's your problem, and there is no good way around it. You have a very long driveway, and as you noted, it also needs to be built up. That takes loads and loads of fill. No good suggestions...sorry:(
   / Best material and practices for 2000' driveway #17
well if you have a tractor with a box blade. and i hope it also has a FEL (front end loader bucket on it) i would say DIY gravel road time!
you will be using the tractor to maintain the road in the first place. so you might as well build it yourself as well.
a cheap easy way to tell grade. besides using all them fancy laser thingies. is to make a "water level" see below link. they are very cheap and very easy to use. and much better than trying to use strings.
DIY: Water Level Gauge
for you i would suggest getting say 150 feet of garden hose. to use as the main hose portion with ((good new washers in the ends)) then some clear plastic hose for each end. so you can see the water level. awesome part, you can drag the hose were ever you want, even around corners and across ditches and get a perfectly accurate water level reading. ((well as long as you don't have any leaks))
the link i couldn't remember, someone else posted it, in another thread woot!
A Landowner's Guide to Building Forest Access Roads - Introduction
i would say conctact the local "gravel pits" in your area. they might be under "dirt", "sand", "rock" categories in your phone book. for me, they don't offer a discount as in more you buy more you get off, just a simple straight fee. over the years i have tried calling hauling companies and contractors for delivery fees. but they were either same or cost more. vs just going with the "gravel pits" haulers/drivers
i was only getting 3 to 4 loads of 16 tons of rock at a time over the years. and was limited to one local "gravel pit" but if i was going to get enough loads being delivered, some of the other "gravel pits" would start thinking about it.
check your property, for fill, as in, take off the top soil, and see if there is any good fill dirt underneath. and at same time redo some landscaping on property, to get the dirt ya need for the driveway.
if ya don't have ditches, that be a spot to look first for some fill dirt.
   / Best material and practices for 2000' driveway #18
My guess based on the description of your soil type, you don't have many stones on your property? My last house I constructed I had a 1200ft drive and I used an old rock wall for 2/3's the way. If I had not done this, the cost would have likely been comparative to your quotes. It made for a great base as it had been there for so long. I am currently looking at moving a current stone wall for a trail/road through a low point in my current property.
   / Best material and practices for 2000' driveway #19
hmm, how bout you pave it with gold, then list your address. hehe
i need some quick cash to buy some more implements LOL:thumbsup: :D :D
   / Best material and practices for 2000' driveway #20
This is a good point. Asphalt millings have value but often the cost of transport from the jobsite to the "dump site" can get high if you are talking serious mileage. We did some roadways at our fairgrounds last year. The contractor saved a total of 12 miles per trip-secondary road dropping it at our site vs. going back to their plant. We took in 30 loads (trailer dumps) in about 4 hours. I think our cost was about 8 bucks a ton. So find out if any milling is going to take place in your area in the future. I also agree on the comment on the dozer. We did our fairgrounds job with 3 pieces- a 420 Cat TLB, A Fiat/Allis (like D-4 size) and an 86" Ingersoll Vib roller. I bucketed the material with the 420, another guy was spreading with the dozer (good eye) and third guy on the vib roller.
You can rent a vib roller-maybe not an 86" -but evan a smaller one will do a good job- millings are great-just make sure you pull any chunks- and try to do it when you have good heat (sunlight). it gets better with age. We averaged around 3" in depth.
I also think fabric is a good idea. ydou have a lot to do- maybe you do it in phases-check to see if someone is going to be in a surplus fill situation in your area as a first step.
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2006 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A60429)
2006 CATERPILLAR...
2017 FORD E-350 SUPER DUTY 16' BOX TRUCK (A60430)
2017 FORD E-350...
