Best lubricant for HST pedal damper cylinder
   / Best lubricant for HST pedal damper cylinder #1
malk315
Lancaster, MA
Kioti CK20 HST
My HST pedal felt a little (very minimal) stiffer than usual.
Found the grease fitting under there I saw in another thread and greased til some came the joint at the front near the fitting. Is this the only one involved?
The damping cylinder looks clean and OK -- I was wondering what is the best lubricant to spray on the piston rods going in and out of the front and back of that cylinder. This is the cylinder that looks like a mini shock absorber.
My machine was manufactured in 2003 (bought in 2006) and dealer upgraded pedal w/ new bushing that requires cracking tractor in half as it was stiff from sitting outside for a while on dealer's lot.
Just wanted to know the best lubricant in your opinion. I've read WD-40 isn't so great -- what about this PB blaster I read about on here? I haven't seen that here in the northeast but will order it from somewhere if it will work the best. Thanks.
   / Best lubricant for HST pedal damper cylinder #2
PB-Blaster is a better penatrating oil than WD-40... but it is a penatrating oil, not for lubricating things on a regular/long term basis. Seems to me I picked some up at a NAPA.
Hmm... need to see what, if any, lubricating points I have on my CK30 HST pedal, I don't remember seeing any when I did mine. :eek:
   / Best lubricant for HST pedal damper cylinder #3
Silicone spray is great for things like that as it does not attract dirt once it dries.
   / Best lubricant for HST pedal damper cylinder #4
I use motorcycle chain lube...
It's thin and sticks well.
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2008 IC Corporation PB205 Bus, VIN # 4DRBVAANX8A506494 (A51572)
2008 IC...
New/Unused CFG Industrial QK20R Mini Excavator (A51573)
New/Unused CFG...
2015 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
