Best lawn mower in $2-4,000 range?
   / Best lawn mower in $2-4,000 range?
+1 on the comfortbable seat. I don't always mow all of it. I do a couple acres regularly, but if I had a better machine, I'd do more of it more often. Can break it up as necessary. I just know my lawn tractor, while it gets the job done, is not really what I need long term for this work. Top 2 desires is something with a much larger and stronger deck, and something stable on hills.
   / Best lawn mower in $2-4,000 range? #22
I recently purchased a hustler 46 for 3500; actually my wife got it for me. I was skeptical of the smaller deck and only 22 hp but it very nimble,fast, cuts great and able to stay in tight spots. I just mowed about 3 acres last nite of fenced yard with bushes trees etc. And done in less than an hour. My old standard riding mower would've taken 2+. The only thing I don't like is that I have to keep both hands on the sticks; I used to like throwing a couple back while mowing but oh well
   / Best lawn mower in $2-4,000 range? #23
riding lawn mowers on for 6 to 7 acres = dead riding lawn mower. been there done that.
at moment having an old allis chalmers CA tractor with a 60" or something like that belly mower. it is a row crop tractor or rather "tri cycle" narrow front end, were front tires are side by side. with split left and rear breaks. this tractor, operates much like a zero turn mower. it has broke down a couple times, but still runs like a champ. it does have R1 / Ag tires on the rear. and does tear up the lawn some. when i lock up left or right brake pedal and spin around a tree in 3rd gear. but could care less. not wanting a golf course look. just wanting to keep things mowed and looking half way descent. after a rain everything for most part goes back to normally for the grass were i did tear things up some.
the CA is 20HP 4 cylinder gas engine on it. and not one of them little gas engines on a riding lawn mower. this gives me plenty of extra torque and HP to let me mow in a faster gear. and really does cut mowing time in half when compared to old riding lawn mowers in the past.
higher ground speed is a must. for that many acres. and riding lawn mowers just never come close. you might be able to find a commercial zero turn mower that allows for the higher ground speed. and still be able to deal with thicker and taller grass.
there is also a vibration difference getting away from riding lawn mowers vs larger size tractor or ZTR. and that is on a riding lawn mower, once you get off, your inter body is shaking and feeling kinda numb over your entire body for a while. while larger tractors and ZTRs there is less vibrations if any at all besides bumps in the lawn you drive over. those vibrations for me is a big one.
with above said, pay attention to "gear speed" or rather ground speed for tractor or ZTR. and width of deck. and how long it will take to mow 6 to 7 acres. there is a good amount of online calculators out there. to plug in, deck width, ground speed amount of lawn you need to mow.
   / Best lawn mower in $2-4,000 range? #24
while i agree on the cheesyness of your typical lawn tractor these days, i have 650+ hours on my craftsman 26hp riding mower that is on its 4th season since i bought it new. i bought it on clearance for 75% off its retail price. while its certainly not very well made, it sure has surprised me as to how well its held up. it mows 3 acres a week, plus pulls the wagon around the yard for whatever. it mows 12" grass all the time, goes up very steep hills, goes across some pretty steep side-hills. i have yet to do anything except change the oil, and i am not very ncie to it
   / Best lawn mower in $2-4,000 range? #25
I couldn't pass by that would not write here, although I also know that the topic is content with the old one, it's just that when he himself solved this dilemma, someone can come in handy in the future.I'm a homeowner and I just spent the last 2 yrs looking and pricing zero turns. I was going to buy a Dixon Ultra52 Dixon Ultra 52 - Zero Turn Mowers or it's Husqvarna 5225 5 Best Lawn Mowers For Steep Hills To Buy Online - BestOutdoorItems counterpart which is about the same mower just painted a different color. Each comes in a few different variations and these are entry level commercial grade mowers. They can be bought on sale for about $4299.00. Yes, you can spend less and get a decent ztr but I feel these Dixon/ Husqvarna give you the most bang for your buck!
   / Best lawn mower in $2-4,000 range? #26
I am a big fan of Toro/Exmark and Hustler. I didn't pay much over your top target for my MX5400 Titan Toro and its a full commercial mower aimed at large landowners and entry commercial customers. It has full suspension seat, fabricated deck, commercial grade hydros and its heavy and big commercial sized wheels and tires. Mine has a Kawasaki engine. I think is more in the $5500 price range now and I think they use Kohler commercials in them now... but its worth it. Good solid machine. Good used one of any of those that has the bigger commercial grade hydrostats and has enough weight to stick on the slopes will likely also have a suspension seat.
   / Best lawn mower in $2-4,000 range? #27
Exactly.
   / Best lawn mower in $2-4,000 range? #28
If you can stand a regular rider and a 46" cut, the Husqvarna 46" does a super job on wet grass.
it's only 2 blades so you have better control of sweeping grass out from under the deck.
The height of the deck is much higher than most I've seen allowing for better sweeping of clippings out the chute especially necessary on wet tall grass.
The deck is stamped and the stampings are curved nicely again allowing for smooth grass flow and minimal clogs.
The worst are the welded steel decks like on my Fastrack 44 ZT, DR 52 ZT, and Ferris 61 ZT.
   / Best lawn mower in $2-4,000 range? #29
Safford Equipment has some deals on bundles
OP here 11 years later.
I'm sure I documented this elsewhere, but I ended up running my JD lawn tractor until it was about kaput. Then, I had done most of the "big" things I had wanted to do with my L3800, so I ended up selling the L3800 and buying a BX 2370 at that time with the 60" belly mower. Worked wonders. I eventually traded it on a BX2380 and it is still going strong performing many duties. These BX's and the other subcompacts are amazing machines that also cut a lot of grass fast in much worse conditions than a lawn mower could ever handle with very little effort and huge fuel and time savings.
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2015 Freightliner Squirt Bucket Truck (A55973)
2015 Freightliner...
2013 KUBOTA SVL90-2 SKID STEER (A52709)
2013 KUBOTA...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
2010 Ford F-150 Single Cab Pickup Truck (A55973)
2010 Ford F-150...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
