Best Landscape Rake for the money?
   / Best Landscape Rake for the money? #1
Mahendra420
Valdosta,Ga
Mahindra 2810
Just tried a Chinese brand worked fine pulling when pushing tho it folded up like an accordian.:thumbdown:
   / Best Landscape Rake for the money? #2
Check this one: Landscape Rake for Compact Tractors
Heard of those should I go with $620 or the $840 version in the 5 foot?
Tractors a 28 HP.
   / Best Landscape Rake for the money? #5
Tractors a 28 HP.
What are you raking?
Heavier is usually better. :thumbsup:
Debris roots logs leaves.
   / Best Landscape Rake for the money? #7
I have one from everything attachments that we have used a good bit. The weak point is around the pin pivot connection to the tooth bar. I've had to reweld the braces once and will have to do it again soon. Probably would be no different with another brand. Do take weight into consideration as heavier is better, not always in construction, but in use of the implement.
I'm an engineer and didn't know I think in a past life I worked for a German tank division that noticed stress.
OCD as well.
Those negative Waves.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A53843)
2004 FREIGHTLINER...
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
2015 Mitsubishi Outlander Sport Multipurpose Vehicle (MPV), VIN # 4A4AP3AU0FE026699 (A53424)
2015 Mitsubishi...
