Best jack placement point?
/ Best jack placement point? #1
erda
Alberta
Kubota B2601
Getting ready to install chains for the first time on my B2601. Where is the proper/best jack placement to lift the rear of the tractor?
Thanks.
/ Best jack placement point? #2
Most people just lay the chains out and drive onto them.
/ Best jack placement point? #3
I stuffed the jack under my drawbar when lifting the rear on my L3200 when dealing with a punctured tire.
/ Best jack placement point? #4
I use the drawbar socket area to lift with a hydraulic bottle jack on my b2620. Make sure the loader bucket is down to help stabilize the tractor.
/ Best jack placement point? #5
I lay out the chains behind the tires. lower bucket o ground. Put the trans in neutral and jack up under the center draw bar. Lift one chain and hang it over the tire lugs then rotate the tire forward which picks up the chain as the tire goes around. Repeat on second side.
Fronts I pick wheels off ground with loader and put chains on.
Never timed it but I'll guess it only takes me about 20-25 minutes.
/ Best jack placement point? #6
I've done the drive over and found it more difficult than jacking the rear end at the draw bar area. IIRC, I set it centered to lift both sides, but put a block under the opposite side as the chain is hoisted on. This prevents it from teeter tottering as you work on one side. Have it in neutral. You can block the front tires if you prefer.
Well, tried to mount the chains today, only to find that there isn't enough clearance to the fenders.
Time to look for some spacers. Suggestions as to a good source?
Thanks.
/ Best jack placement point? #9
While you're solving the clearance problem, I lift under the axle and put the jackstand nearby. Also a second jack under the drawbar because they are HF jacks. I never could make it work driving over them.
43018CFL (A59228)
43018CFL (A59228)
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
Colombo CTA 6500 (A64119)
Colombo CTA 6500...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
2002 WACKER RD25 ROLLER (A59912)
2002 WACKER RD25...
26 ft trailer 20 ft bed (A61567)
26 ft trailer 20...
