Best Item I have Ever Bought for L3650
   / Best Item I have Ever Bought for L3650 #11
Here you go! The sliders were a little harder to make for the 2660, because of the front plate. It has to be cut in half and cut line has to be shimmed back in (1/8"). Also a bolt with a bushing has to be put in it. One other thing, the aft. ends have to turn just a little.
My 3pt arm that go to the top and bottom arm were welded wrong from the mfg. the leftone I cut and welded back in the right spot. The right one I just turned the bottom half 180 deg. The 3pt would not go all the way up and down without locking up tight.
   / Best Item I have Ever Bought for L3650 #12
I didn't say everything I wanted in the other post because I have something running in the background on this thing and I get knocked off sometimes and I didn't want to loose the pictures.
Maybe if you can find out the price of the front plate and it's not to much I could help you make a set. The old plate and turn buckles you can put back on if you sell or trade it. All the other stuff I can get and made here, now that I got mine to go by.
My 3pt was so missed up it took me 2 days understand what was wrong. Does yours lockup when you go all the way down and all the way up? By locking up I mean is there any side movement when all the way up and down. I had to stand on mine to get it all the way down. I also drilled a about 3 or 4" fwd so it can drop down more, as you can see in the pictures.
PS if that front plate is in your price range I can pick one up here and save on shipping. I can't say what the steel would cost because I had most of it.
   / Best Item I have Ever Bought for L3650 #13
LeeJohn,
Great pics, thanks. Appreciate the offer on help to fab. I will check on the plate cost. I am back in LV for the winter and the 2660 is tucked in the garage for the winter. I will PM you as I research the plate. Will be back in Joplin in the spring. I have no problem with the 3PT up or down or locking up.
Jim
Leejohn - Very talented. Wish you were closer. I would pay you to make one for my L3650.
   / Best Item I have Ever Bought for L3650 #16
Forget to ask if the white feather friend in your pic is still around guarding your BX;):licking:?
Yes she is still here.. Her name is Xmas, but I think she well be with me for along time. I can't kill anything, even have a hard time sometimes killing copperheads.
Send me a PM with your email address
   / Best Item I have Ever Bought for L3650 #18
LeeJohn,
I really like the loops for holding your lynchpins on the telescopic release levers. Did you add those? I have been clipping mine to the ROP lock bolt eyes when the implement comes off and trying to think of a better solution. I think yours are the solution I wanted to think up!
-Jim
   / Best Item I have Ever Bought for L3650 #19
Yes I made everything for the arms.
Wolverine Quick Attach Hydraulic Winch (A50514)
Wolverine Quick...
FELLA TH800 HAY TEDDER (A51243)
FELLA TH800 HAY...
2004 GREAT DANE 53FT DRY VAN TRAILER (A52141)
2004 GREAT DANE...
2007 Chrysler 300 Sedan (A50324)
2007 Chrysler 300...
CRATE OF MISC HYD HOSES (A51244)
CRATE OF MISC HYD...
FORD 2000 TRACTOR (A51243)
FORD 2000 TRACTOR...
