Best Hydraulic Transmission Oil and Filter
   / Best Hydraulic Transmission Oil and Filter #1
rmankty
1948 farmall cub
Hello, We have a zero-turn radius mower bought new,a John Deere 737 Ztrak. The OEM oil is JD 15W40 or SAE 15W40 and the filter is AM131054. The price on this filter quoted at $17.99. I want to make sure I have no trouble with this machine. Any recommendation you can make I appreciate. I can get a WIX cross-ref 57103 for $8.50 at local auto parts store and their Co. brand of SAE 15W40 for about $14 a gallon. Any better ideas? Thank you for your input!
   / Best Hydraulic Transmission Oil and Filter #2
How often will you be changing your oil? Why not support your local dealer? At least buy the filters from them.
The filter for the 1635 is $42, change it biannually. .
   / Best Hydraulic Transmission Oil and Filter #3
They are using engine oil in the transmission?! That's different.
What does the owner's manual say the oil change schedule should be? That's usually a good start...
   / Best Hydraulic Transmission Oil and Filter #5
The problem with support the dealers around here is that they dont support you. Gouge you on price of the equipment, ( as compared to other dealers) and really rip you off on parts, (again compareing to other dealers). Air filter $80 at dealer and $20 at parts store for same brand. I rest my case. I have no feelings of needing to support my local dealer, especially when I am the one putting out the cash.
Amsoil synthethic works great in hydrostatic systems, and you can use dextron3 transmission fluid. Stick to manufactors specs and use the brand of oil that meets those specs and matches your pocket book. Filters are usually 10micron, but I have seen 20micron on some systems. I cant say for sure, but Wix makes filters for a lot of companies and all wix filters are made to manufactors specs, so you should see no issues subsituting wix for the JD brand.
2012 Honda Civic Sedan (A55758)
2012 Honda Civic...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
UNUSED RAYTREE RMRB72 - 72" POWER RAKE BUCKET (A54757)
UNUSED RAYTREE...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
12in Mini...
