Best Hydralic/Transmission oil
   / Best Hydralic/Transmission oil #1
D40
My Mitsu MT372 uses combination hydralic/transmission oil. Someone sugggested using 80# gear oil. Is the combination oil I see in automotive stores the same as 80# gear oil? Are there any recomendations on the best oil to use in this application?
Thanks, D40
   / Best Hydralic/Transmission oil #2
D40
80# gear oil would to heavy (thick) for the hydraulic pump. Use the manufactures recommended oil or Universal Hydraulic Fluid available from TSC and Tractor dealers.
   / Best Hydralic/Transmission oil #3
Does your Mitsu have wet brakes?
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2011 Ford F450 Diesel with Just 156638 Miles (A55218)
2011 Ford F450...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
2022 CATERPILLAR 302.7 CR EXCAVATOR (A52705)
2022 CATERPILLAR...
Komatsu WA180-1 Wheel Loader (A47477)
Komatsu WA180-1...
